Home > Help Needed / General Tech Chat > One for the Metro Turbo owners - coolant plumbing
Thanks Joe,
Elegant simplicity.
But you're not on a T3 either, are you ???
or you would never have got that expansion tank where you have it..... I can't !!!
Having looked at everyones posts so far, it has given me a few more ideas, so thanks all :)
its non turbo at the moment, i just thought the mini bottom hose solution might help,
getting the header tank in was a PITA, too big and competly the wrong shape :/
No, the bottom hose is a neat way of doing it - I hadn't thought about letting the hoses go that far "out" into the wheelarch.
The header tank is the starting point of all my problems, the one I finally settled on is also too big, but worse than that, my brace bar assembly puts it too far inwards, right where the turbo inlet hose and coolant hose get in the way of each other......
