| Home > Technical Chat > Torque/VE | ||||||
857 Posts Member #: 1778 Post Whore Northants |
29th Sep, 2010 at 08:46:39am
I believe the run that produced more power was actually on less boost |
29th Sep, 2010 at 09:36:02am
What he ^^^^ said. The logs from the MS confirm it. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Sep, 2010 at 10:42:21am
I have a theory. A little tenuous, but worth a thought.
78 Posts Member #: 9073 Advanced Member Edinburgh |
29th Sep, 2010 at 11:11:22am
Is it not an exhaust side limitation?
29th Sep, 2010 at 11:33:01am
On 29th Sep, 2010 Nial said:
Is it not an exhaust side limitation? You can wind the boost up to get as much in as possible but this doesn't improve the exhaust situation, at higher speeds the exhaust isn't properly emptying the cylinder so you get a massive loss in torque? Could well be. I'm sure that all the above except mine use the MT exhaust manifold. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Sep, 2010 at 12:04:03pm
Is this to do with the mis-match in valve sizes, or is it the manifold/turbo restriction?
29th Sep, 2010 at 05:03:46pm
Is this to do with the mis-match in valve sizes, or is it the manifold/turbo restriction? Do many other heads have the mis-match in valve sizes that the A series has? Do you get the same problem with an 8 valve head? If you know you can get all the air in the inlet you need is it worth leaving that standard and trying to increase the exhaust valve as much as possible (what are the options here)? Not sure what you mean about the mis-match. They are all 8 valve heads. Some of the 1275s are 33/29, some 35/29 and one is 35/31. Ben's 998 has 33/29 and mine are 31/26. Larger exhaust valves are a benefit as is longer exhaust duration, but there is more to it than that. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Sep, 2010 at 05:20:00pm
Sorry meant 8 port heads.
29th Sep, 2010 at 05:36:22pm
Similar problem with the 8 port heads but it is far more proportionate to boost.
29th Sep, 2010 at 05:38:45pm
Yep I use the metro exhaust manifold and a maniflow exhaust. |
29th Sep, 2010 at 06:07:07pm
im using the metro turbo inlet and ex . then 53mm downpipe. 36/31 valves .
30th Sep, 2010 at 05:21:15am
The drop in ve is supposed to be tip/manifold pressure induced.
30th Sep, 2010 at 11:24:13pm
hum,
1st Oct, 2010 at 07:06:44am
could it be the speed of the burn staying the same but the time to extract the useable power is halfed (say 3k to 6k)
Yes i moved to the darkside |
1st Oct, 2010 at 08:06:01am
Intercooler efficiency?
1st Oct, 2010 at 08:10:34am
Just thinking about manifolds.
1st Oct, 2010 at 10:59:01am
On 30th Sep, 2010 Joe C said:
hum, I', just thinking if you retard the ignition 8 deg is it likly to increase the torque at 3000-3500 like in that graph... I think yes, the the burn/ expansion will be later so when the engine is turning slower the peak pressure is later where the the leverage angle is more, but a lot of the energy is wasted, blah blah blah.... makes sense in my head though... can you tell i've been dringing again Paul! Haha, alcohol blurs the senses. Could be that we just need to add a little more advance in that area. We just adjusted the map at the top end. On 1st Oct, 2010 wil_h said:
Just thinking about manifolds. If you plonked any of the turbo manifolds we use on an NA engine you'd expect a drop in power compared to an LCB, so there is some restriction. However, in our case, there is a further restriction beyond the manifold in the shape of a turbo, so the manifold is not the most restrictive part of the exhaust system. so in my eyes any improvements you make to the manifold will be pointless as you still end up at the same restriction. At the top end of the rev range the waste gate will be open, can these be made more efficient? I think Pauls comment on the efficiency of the 17 turbine is relavent. My personal opinion is that some of the graphs above show reasonably well optimised engines with minimal drop off in torque and way better than an NA motor. I think that there may be more to it than just pressure loss. There is a number of significant energy state changes from the exhaust valve to the turbine wheel, pressure, temperature and velocity all play a role. Each change of state has an inefficiency that will ultimately impact VE. However, I agree that the exhaust manifold is the least likley candidate for significant improvement. Having said that, mine is the only one not using the MT manifold. I'm starting to get used to the fact that if i want over 100lbft at 7500rpm, then i've got to have 120/130 lbft at 6000rpm. Ultimately, this thread is intended to help me decide on the best cam for the 998Ti Stage 2. I've bought a brand new GT1752 and the pistons and head are on order. Got to make a new exhaust manifold but it will be similar to the existing. I'm limited on valve sizes, 31/26.5, with the 12G295 as i want to have unleaded seats fitted. I just wonder if that may be a little limiting. How about some 1.3 or 1.5 rockers on a modest cam? Edited by Paul S on 1st Oct, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Oct, 2010 at 11:10:46am
OT but where did you get your GT17 from Paul? What was the pricing like? If something is worth doing, it's worth doing half of. |
1st Oct, 2010 at 11:16:48am
Well, results on the rollers at the weeknd for the Sprint might be interesting then as it has a non-metro manifold. also I run the 266 cam.
1st Oct, 2010 at 11:19:36am
ebay. M5 Saab Centre. £350 plus postage. Just a one-off I think.
1st Oct, 2010 at 11:21:13am
Cheers Paul.
1st Oct, 2010 at 11:34:28am
On 1st Oct, 2010 John said:
TBH I will prob stick with the delivery mile GT20 I have. However I have been so impressed with the GT17 figures that I have found my interests wandering. I would stick with the GT20 for the ultimate 1275. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Oct, 2010 at 11:50:05am
I'm sure Steve squeezed 29mm ex valves in my 295 with inserts. Any issues with using 1275 valves? I've done it on the lads na 998s, but cut them down to 26mm. Used a spacer under the valve springs. I've got some 33/29 214N valves that I could try. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Oct, 2010 at 12:01:07pm
Well If I blow the head gasket tomorrow you'll be able to have a good look!!!
1st Oct, 2010 at 12:36:47pm
Not sure that the 29mm exhaust valve will gain much over the 26.5 due to the shrouding. The gap between the chamber wall and valve gets very restrictive, with a lot less area than the curtain wall. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
