| Home > Help Needed / General Tech Chat > supercharger tensioner and no noise! | |||||||
54 Posts Member #: 8588 Advanced Member Yeovil |
10th Nov, 2010 at 10:22:59pm
I recon your tensioner setup is bent! Graham |
![]() 871 Posts Member #: 2590 Post Whore Croydon |
10th Nov, 2010 at 10:32:55pm
see i was thinking this earlier on i have removed the the tensioner bracket and it looked like it was cracked (on the weld)
11th Nov, 2010 at 04:19:15pm
Glad you've got it sorted! Graham |
11th Nov, 2010 at 06:51:11pm
going to have to get a new tensioner i got a sleve today and the tensioner still wobles it must be the bearings inside.....
11th Nov, 2010 at 07:48:08pm
Cossie one works really well, I'm very please with this setup. You'll have to machine a spigot for it, but its nothing special.. Graham |
11th Nov, 2010 at 08:18:39pm
bit of a noobish question but what is a spigot |
11th Nov, 2010 at 08:20:08pm
11th Nov, 2010 at 08:51:42pm
really and how would i go about putting one on (my tensioner bracket) |
11th Nov, 2010 at 11:06:20pm
Basically it’s a bolt that goes through the jockey wheel. It will need to be an interference fit so a little machining will be required Graham |
11th Nov, 2010 at 11:32:54pm
I wouldnt have thought it would be an interference fit, how would you tighten it properly? The bolt is a clearance fit. An interference fit means that the two parts interfere with each other as one part is usually larger than the other part it fits into.
11th Nov, 2010 at 11:49:07pm
The 'interference’ fit is only 5 thou or so (I’m not a machinist by trade), so the spigot had to be pushed though with a little force. What I didn’t want happening was the centre moving indicated by the red arrow. In my opinion the width of the jockey wheel isn’t crucial as long as all the pulleys line up properly. I paid a lot of attention in this area, after aprox 2500 miles there hasn’t been a problem. The belt I used wasn’t brand new either, it had done 15000 miles in a BMW mini.
Graham |
12th Nov, 2010 at 10:05:40am
could you possibly do a step by step ?
12th Nov, 2010 at 10:17:51am
On 11th Nov, 2010 Grahamxx said:
The 'interference’ fit is only 5 thou or so (I’m not a machinist by trade), so the spigot had to be pushed though with a little force. What I didn’t want happening was the centre moving indicated by the red arrow. In my opinion the width of the jockey wheel isn’t crucial as long as all the pulleys line up properly. I paid a lot of attention in this area, after aprox 2500 miles there hasn’t been a problem. The belt I used wasn’t brand new either, it had done 15000 miles in a BMW mini. ![]() I see now what you are doing, which i supose is one way of doing it. If it was me, I would design a mounting bracket as I have already discussed, making the bracket very stiff resisting any movement, and then used the off center hole on the tensioner to put the tension on the belt. I am not saying that is the right way, but its another way and the way I would do it, but then I am pretty anal when it comes to stuff like this
12th Nov, 2010 at 10:37:21am
The Cossie tensioner should not be an interference fit on the bolt, it should have a (very small) clearance.
12th Nov, 2010 at 03:39:54pm
The reason why I made the spigot an interference fit is I didn't want the center boss to move at all. By swinging the bracket in an ark this would then tension the belt. Graham |
