| Home > General Chat > ally block | |||||||
18th Nov, 2010 at 10:58:27am
I'm all for bending the rules, but that really isn't what it says.
On 18th Nov, 2010 01smartc said:
I think you could use it in hillclimbing aswell. As long as it looked exactly the same from the outside.... but thats the problem. I dont think you could make one look the same. Chris Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Nov, 2010 at 11:08:57am
What about when sourcing a good block becomes difficult, this is the main advantage. |
400 Posts Member #: 2563 Senior Member Tamworth |
18th Nov, 2010 at 11:13:11am
I do agree with you wil.
18th Nov, 2010 at 11:30:55am
Well there are rumours that S blocks are going to be recast, so if there is a need otheres will too.
Edited by wil_h on 19th Nov, 2010. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Nov, 2010 at 11:50:38am
Who's re-casting the S-blocks out of interest Wil? If something is worth doing, it's worth doing half of. |
18th Nov, 2010 at 02:49:29pm
I'm sorry, I am not trying to be rude, just stating the facts in an efficient manner. As it has now been elaborated on above I stand by my original comment.
On 18th Nov, 2010 carl talbot said:
On 18th Nov, 2010 Ben H said:
Then you understand it wrongly. Of course I do - anything you say sir http://www.twin-turbo.co.uk
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
18th Nov, 2010 at 05:59:12pm
On 18th Nov, 2010 gavin@minispares.com said:
What about when sourcing a good block becomes difficult, this is the main advantage. Hoarding is the awnser Get them whilst they'r still cheap... I store every block & engine I can get my fingers on
It would be something else if KAD would make a block with 5 main bearings that fit's "plug & play" ontop of a Mini's gearbox. This I could somehow understand. But it still leaves us with a weak-ish gearbox. I can't see KAD earning money with an aluMINIum block - but it'll certainly make a good addition to KAD's portfolio
[X] nail here for new monitor |
18th Nov, 2010 at 06:29:14pm
I want an S block! On 28th Aug, 2011 Kean said:
19th Nov, 2010 at 05:24:01am
This is right..
On 18th Nov, 2010 wil_h said:
Well S blocks are already being recast, so if there is a need otheres will too. Well the rules do say you can do what you want internally iirc. This is ment to mean fit posh bits not sure it means put another engine inside it. To be honest the head is what makes power, the crank et'c just needs to cope with it. I'm happy that you can build a pretty resilliant A-series, so what's the point in putting another engine inside the a-series? Just to further think about the theory of using the A-series as a cover. Say you managed to get a Hyabusa engine in there that made 200 bhp, well that would be at 12k (I guess). Now that's nearly twice what I rev to and I have a 4.1 diff; what unavailable diff will be needed to make use of the power. Maybe useful on a dragstrip or circuit, but on a hill you'd just not have the right gears. Well I'm sure it's all possible, but for cost vs advantage it's a non-starter for me. whether it's eligable is one for the MSA. |
19th Nov, 2010 at 07:36:31am
Edited post as they are only rumours that I have heard so don't get your hopes up. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
19th Nov, 2010 at 12:11:41pm
been busy machining a big slab of alloy www.miniman.com.au
