| Home > Help Needed / General Tech Chat > Coolant plumbing... | |||||||
4th Feb, 2011 at 12:27:19am
I'll throw a spanner in the works Rod On 26th Oct, 2004 TurboDave16v said:
4th Feb, 2011 at 08:08:14am
So am I still OK with my water coming from the drain plug at the back of the block ?
4th Feb, 2011 at 09:06:53am
Sorry Colin, it must be the wrong sized spanner you handed me :)
4th Feb, 2011 at 11:04:48am
The cooling system static pressure only rises when the engine is shut off, therefore, the rad cap maintains the maximum static pressure during heat soak. With the engine running, the max available pressure at the suction of the pump will be zero gauge pressure since the cooling system on Minis excepting the MPi should never see 100 degrees for the water to boil sufficiently to raise the pressure above zero. The rad cap is only ever there to prevent the cooing system boiling over when the engine is shut down and in heat soak, causing the coolant to boil rapidly. An overheating engine will boil the coolant while it is running and as a result will lift the rad cap. But the rad caps purpose is not to maintain pressure in the cooling system of a running engine. To pressureise the cooling system to 1 bar, the coolant temperature needs to be 120 degrees in the rad. and if I am not mistaken, the rad is usually the coolest place in the cooling system This is so wrong. First law of thermodynamics, school boy science, tells you that if you heat water in a closed container, the pressure goes up. The cooling system of an engine sees quite a large range of pressures due to the pump with the thermostat being the main cause of resistance. The thermostat holds pressure in the head to prevent the heat boiling the water. So if you want flow through the turbo, take it off before the thermostat and feed it back in after. If you want that water cooling, then put it back in the top hose. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Feb, 2011 at 05:22:24pm
Are we talking about a full to the brim cooling system, or a cooling system that most of us use with a vapour space at the top? On 26th Oct, 2004 TurboDave16v said:
4th Feb, 2011 at 05:36:45pm
One with a "vapour space".
4th Feb, 2011 at 05:42:29pm
To my knoledge sprox is correct...
4th Feb, 2011 at 05:52:22pm
still dont see how you get a pressure greater than one atmosphere at a temperature lower than 100c. If anything with a cold engine, the cooling system is subject to a vacuum
4th Feb, 2011 at 06:00:44pm
I can kind of see where jamie is coming from (even if he is a bit cock sure). To pump fluid you need to create a high pressure to flow into a lower pressure. The water at the point it leaves the pump must be at a higher pressure than the water in the block. The water in the block must then remain slightly higher than the rad in order to flow back, the difference is probably not much, but big enough.
http://www.twin-turbo.co.uk
4th Feb, 2011 at 06:04:09pm
On 4th Feb, 2011 Paul S said:
One with a "vapour space". As the engine warms up, the water expands into the "vapour space" as you call it. As the air and water are in equilibrium, the compressed air in the space then exterts a pressure on the water. As long as the water/air ratio is unchanged, the pressure in the radiator is maintained by the compressed air. Evaporation is a surface phenomenon as a result of the partial pressure of the 'air' above it. Bubbles in the volume of water cannot form due to a high vapour pressure, and a 'low' temperature. Boiling is a volume phenomenon where bubles of vapour are formed in the main volume of the water as a result of its temperature and saturated vapour pressure. saturation pressure is the pressure at which both liquid and gas co exist, at specific temperatures. Water at 1 atmosphere has a saturated temperature of 100c and 120c at 2 atmosphere. On 26th Oct, 2004 TurboDave16v said:
4th Feb, 2011 at 06:04:13pm
Apart from the First Law of Thermodynamics (which applies the initial pressure), try schoolboy science lesson No 2.
Edited by Rod S on 4th Feb, 2011. Schrödinger's cat - so which one am I ??? |
4th Feb, 2011 at 06:36:21pm
Ha, reading this is there no thread on tm that doesn't end without decending into smut or some scientific debate?:) On 7th Oct, 2010 5haneJ said:
4th Feb, 2011 at 06:53:01pm
Boiling is a volume phenomenon where bubles of vapour are formed in the main volume of the water as a result of its temperature and saturated vapour pressure. NO.... vapour bubbles can be formed outside the main volume of the fluid well below the bulk boiling temperature if they are being produced from a surface that is above the bulk boiling temperature (like the internals of a cylinder head near the exhaust ports or exhaust valve guides, or like my kettle example). The majority will subsequently collapse and recondense to liquid as they migrate through the sub-cooled fluid, some will reach the header tank, but the fact they exist in the first place is what applies the pressure.... But you're all still ignoring my point about the pump....
4th Feb, 2011 at 07:21:17pm
On 4th Feb, 2011 minimole23 said:
Ha, reading this is there no thread on tm that doesn't end without decending into smut or some scientific debate?:) Hopefully not, but I prefer the scientific debate ones :) (it's probably an age thing )
4th Feb, 2011 at 07:24:24pm
Despite all this erudite discussion (?) I,m sticking with what I,ve just made _ I cant be arsed to change it again- and I wont blame anyone on this thread if it doesn,t work.
4th Feb, 2011 at 07:43:21pm
Any bubles of vapour created from a localised hot spot will instantly colapse when free in the surrounding sub cooled liquid. They will never be able to reach the expansion tank!
4th Feb, 2011 at 07:45:29pm
I enjoy reading the scientific debate, but I much prefer the smut On 11th Feb, 2015 robert said:
4th Feb, 2011 at 07:46:35pm
On 4th Feb, 2011 tadge44 said:
Despite all this erudite discussion (?) I,m sticking with what I,ve just made _ I cant be arsed to change it again- and I wont blame anyone on this thread if it doesn,t work. Can we lighten up chaps and get back to some more interesting stuff ?. sorry mate posted that last while you posted yours. Thing is, This boiling, evaporation, saturated and vapour pressure stuff is the central part of my trade. Infact the most efficient refrigerant we have is H2O, however to take advantage of the huge latent heat capacity at a low level, we need to boil the water at 5*c On 26th Oct, 2004 TurboDave16v said:
4th Feb, 2011 at 08:08:50pm
To finally solve this arguement:
Edited by Carlzilla on 4th Feb, 2011. On 26th Jan, 2012 Tom Fenton said:
4th Feb, 2011 at 08:47:26pm
Any bubles of vapour created from a localised hot spot will instantly colapse when free in the surrounding sub cooled liquid. They will never be able to reach the expansion tank! As for being non scientiffic about the feel of a hose, which hose are we talking about? I've already said most will collapse in the sub-cooled liquid - it's the fact they exist in the first place that maintains the pressure..... The rest go to the expansion tank. A well designed system will deal with this. And any hose, pick your own, just go and squeeze it with your engine hot and running and try and tell me again that the coolant inside it isn't pressurised....... or take the cap off but don't blame me for your third degree burns when the pressurised coolant exits all over you :) Does anyone on here believe that their coolant isn't pressurised when the engine is running apart from Colin ??? Schrödinger's cat - so which one am I ??? |
4th Feb, 2011 at 08:50:55pm
God love you Rod, but give it a rest for now Eh ? |
4th Feb, 2011 at 08:51:47pm
I was under the impression the liquid itself isnt under all that much pressure, but the air in the system is, which is why the top hose is pressurised when you squeeze it, as there isnt water in that part of the hose in anything ive ever taken off when the engine isnt running, but pressurised air.
5th Feb, 2011 at 12:35:39am
I concede that if, and only if there is a total void of air above the coolant in the radiator, that, at 90c there might be a pressure of over 1 bar. As the coolant expands as it heats up, so does the air. On 3.5 litres of water there is roughly a 0.125L expansion between 20c and 90c. Assuming 300ml of air at 20c, at 90c this will have been compressed to a volume of 0.175L as a direct result of the expansion of the water. The air itself has also expanded due to the higher temperature, so using the combined gas law, the pressure would infact be in excess of 1 bar gauge at 90c, thus lift the rad cap and bleed the air out anyway. This has nothing to do with the evaporation or boiling of the coolant and I stand by my statement that coolant in the radiator at 90c will be at or below zero gauge pressure when you open the rad cap and perhaps relieve any air that might happen to be there under pressure.
![]() 489 Posts Member #: 9159 Senior Member Devon |
5th Feb, 2011 at 12:55:26am
So to round it off... it would be fine for both water cooling and good flow to take the water feed from the coolant plug on the block and the return into rad top hose? :) |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
5th Feb, 2011 at 09:38:12pm
On 4th Feb, 2011 Carlzilla said:
I was under the impression the liquid itself isnt under all that much pressure, but the air in the system is, which is why the top hose is pressurised when you squeeze it, as there isnt water in that part of the hose in anything ive ever taken off when the engine isnt running, but pressurised air. Of course there is some pressure applied to coolant when the engine is running, otherwise it wouldnt pump, when the pump stops, the coolant stays relatively still, as there is no pressure. If you take the rad cap off an engine at normal operating temperature, you get steam, as the hot gas escapes. its only when the coolant is properly boiling water, that any of it comes out of the filler cap. If it does, theres something not right. Water and air are both fluids, and the pressure in a fluid has to be the same everywhere, otherwise the stuff at high pressure would immediately rush into the low pressure zone, result, same pressure throughout. If you connected a gauge to the air/vapour space and the liquid itself, they would read the same (ignoring the trivial contribution of hydrostatic pressure due to gravity).The saturated vapour pressure of water at 90 deg C is around 9 or 10psi, and that is the pressure throughout the system. Geoff |
