| Home > Help Needed / General Tech Chat > metal shavings on sump. | |||||||
9th Feb, 2011 at 06:29:55pm
nic have you any clearer pics ?
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
10th Feb, 2011 at 10:17:13am
paper thin very small, might look rusty because i dropped it out side & only found it a few days later under the car.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
10th Feb, 2011 at 01:50:39pm
I'm pretty sure it doesn't matter how small or 'paper thin' this debris is, it means that something in the engine is eating away at something else.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
10th Feb, 2011 at 01:52:35pm
i thought i could be a diff shim,well part of one, On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
10th Feb, 2011 at 02:46:48pm
I was thinking diff shim as well. On 13th Jul, 2012 Ben H said:
10th Feb, 2011 at 05:50:58pm
I couldn't think where there was a circular shim in the box as I couldn't get ball joint shims out of my head!!
![]() 558 Posts Member #: 8143 Post Whore London |
10th Feb, 2011 at 06:09:32pm
Whats the oil pressure like? |
10th Feb, 2011 at 06:34:39pm
Could someone have used shim steel behind the thrust to reduce crank endfloat?
I seriously doubt it! |
10th Feb, 2011 at 06:47:00pm
yes gents diff shim ...... my monies on paul wigintons theory ...... especially if hese an old timer who built the engine
10th Feb, 2011 at 08:39:04pm
I saw it, and the first thing that popped into my head, was I'm hungry and want some dinner. Then I thought Diff shim whilst on the way to the fridge.. I run a supercharger and I don't care the TB is on the wrong side.
11th Feb, 2011 at 01:40:15am
11th Feb, 2011 at 09:33:47am
11th Feb, 2011 at 02:41:11pm
My money would be on a Shim and I would think its the one thats sets preload on the main Gearbox pinion bering, I have seen these some of these work there way out and get shaved by the pinion,
On 17th Feb, 2009 Rob H said:
