Home > Help Needed / General Tech Chat > crank sizing, how do you tell?
Doodmeister
Member #: 149
Alberta, Canada
HO fucking HO i think the saying goes. *tongue*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I bet you set that up specially for this thread!
Alex
AlexF
Ok, so we're bringing out crankshaft pictures are we??
As you all can see, this one's 010/010
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I need a regrind...
AlexF
Doodmeister
Member #: 149
Alberta, Canada
i thought that Vegard as mines STD/STD... LOL
Doodmeister
Member #: 149
Alberta, Canada
Why grind when you can weld....
The one place to visit before you go:
LMAO at all the above!!!
Ladies.....please......
In answer to the original question-
If you don't have access to measuring equipment suitable to measure the crank journals yourself, why not take the crank along to the place that is going to supply you with the new bearings and get them to measure it for you? Any engine machine shop will happily do this for you...............
Doodmeister
Member #: 149
Alberta, Canada
The most basic method I can think of would be to use a piece of paper cut to the circumference of you crank journal and then when laid flat and divided by PI should give you the journal diameter.
You have to be as accurate as you can because for every 10 thou of the journal the length of paper should decrease by approx 1mm.
Mains 1275 A+
STD = 160mm Circumference
+10 = 159mm
+20 = 158mm
Big Ends 1275 A+
STD = 140mm Circumference
+10 = 139mm
+20 = 138mm
Just a thought but might be worth a try. :)
icklebits
Member #: 228
i thought of getting the circumfrence and doin it that way, didnt know if it would be accurate enough, will give it a go 2moz
Dangerous
Member #: 417
A diggy vernier only cost about ?15 should be accurate enougth to determine whether it's -.010/.020" or whatever.also usefull for measuring other stuff pipe sizes/valve sizes etc
And it measures both imperial and metric!
Ebay is a good bet - or screwfix often have them on 'special'
cant you get somewhere to measure it? or a mate to pop round. if you were close enough id do it.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Where are you... no location in your profile...
Alex
AlexF
icklebits
Member #: 228
managed it! cheers for the help, its +10, which also backs up what the previous owner thought (he couldnt be sure)
can get em ordered and get the lump back together now *tongue*
ryan
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
*happy*
sorted
Alex
AlexF
The problem with this paper method is that you don't measure if its conical/oval in any way. When I measure my crankshafts, I measure the jouornals in four places to be sure that it's not oval/conical.
Paper method won't do it for me...
Doodmeister
Member #: 149
Alberta, Canada
Out of curiosity how many have you found that are Oval ?? because I haven?t found one yet give or take 0.0005" from the cranks i've ran.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Me nither...
Just asked a few other people and they never have on BMW engines either.
Alex
AlexF
Big end journals are always conical due to the silly A-series offset rods, and the centre main is always oval. When using the crappy A+ big main bearings, you won't notice, but look at an A centra mian journal, and you'll see that it's worn only on one side.
Dangerous
Member #: 417
Round things can go slightly triangular too which you can't measure with a mic as you pick up on the high spot one side and low spot opposite,Check with a clock and 90 degree v block 8-)
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
