Home > Help Needed / General Tech Chat > twin stage boost?
clubminiflip
Member #: 54
nr coventry
i know i'm not the brightest spark but i'm blummin lost in how to do this now!
confusion attack
Mr Joshua
Member #: 1954
Luton Bedfordshire
I have a two stage on my car very crude but effective. My bleed valve has an internal stop a simple twist untill you hit the stop and voi-la. Like I said crude but effective. And because of the stops you never over boost.
Edited by Mr Joshua on 27th Feb, 2010.
Own the day
clubminiflip
Member #: 54
nr coventry
i'm still lost! cant i use the stock metro turbo boost solinoid?
doi replace the inline thngy with a bleed valve
i take it the stock actuator is set to 4-4.5 psi
the stock boost solinoid valve opens at 4000rpm but if i put a switch on it i can open it whenever i like yey/ney?
from there do i replace the check valve (thats what its called) with a bleed valve? & set the bleed valve to say 10psi? or have i got the wrong pipe
i like the simplist method as i am simple & i can understand it better from there
MarkGTT
Member #: 1194
Shropshire.
On 27th Feb, 2010 clubminiflip said:
cant i use the stock metro turbo boost solinoid? - Yes
doi replace the inline thngy with a bleed valve - what?
the stock boost solinoid valve opens at 4000rpm but if i put a switch on it i can open it whenever i like yey/ney? - yes just get rid of the 'ECU'
from there do i replace the check valve (thats what its called) with a bleed valve? & set the bleed valve to say 10psi? - take a look at the pics mate. Best way looks to stick the bleed valve in line between the turbo and the actuator with the vent port linked to the solenoid, when you hit the switch the bleed valve will become active and vent through the solenoid
clubminiflip
Member #: 54
nr coventry
do i replace the check valve with a mbc?
so its bleeding of more air above 4000rpm?
