| Home > Help Needed / General Tech Chat > cant get my flywheel off | |||||||
16th Jul, 2011 at 07:40:35pm
This is how it sits, assembled with the correct bolts, somebody hadnt used the correct strap to fly bolts previously and so im clueless as to what is right.
16th Jul, 2011 at 07:47:32pm
I'd say you want 4-5 washers under the straps,
16th Jul, 2011 at 08:10:58pm
16th Jul, 2011 at 08:13:49pm
looks good to me.
16th Jul, 2011 at 08:15:10pm
Right, thanks joe :)
17th Jul, 2011 at 01:14:09am
Right, its all back together, and it now feels like its either doing bugger all, or it feels like a modern clutch, which it shouldnt do right?
17th Jul, 2011 at 01:52:05am
I'm not liking any of this. I would like to see a picture of the final assembled clutch from all sides. I just get the feeling that there is something still wrong with this. Just a feeling mind.
17th Jul, 2011 at 01:56:45am
Read this http://www.minimania.com/web/SCatagory/CLU...53/ArticleV.cfm
17th Jul, 2011 at 02:03:32am
another thought.
17th Jul, 2011 at 08:16:28am
Ill take the bellhousing off again later and take pictures. It needs to be finished today, because the car isnt at my house, due to the fact i dont have a garage i can get my car in to work on:/ On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 09:10:23am
If it comes down to dismantling it again, im fitting my med ultralite i reserved for the turbo engine, and pre engaged starter, ive just thought of an easy way of not binning the remote solenoid, by extending the solenoid switch feed, and moving the inertia lead onto battery side On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 11:13:55am
Colin, pictures here, it all looks good to me and clamps together nicely. On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 11:32:46am
By doing bugger all I assume you mean the clutch is not disengauging?
17th Jul, 2011 at 11:45:42am
Ive adjusted everything to the death, the only thing left to try is changing the clutch arm, as it was a little worn on the ball end, although if this was the case surely it would still do something? On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 11:53:34am
In the middle picture, the shoulder bolts that pass through the diaghragm into the posts of the backplate don't look like they are fully seated properly? The head appears to sit too high. The cone spring also looks to be little compressed in that picture but doesn't look too bad on the third picture (it could still be better).
17th Jul, 2011 at 11:57:32am
oh and you are butting the thrust place and lock spring back onto the diaghragm before you put the wock back on? On 26th Oct, 2004 TurboDave16v said:
17th Jul, 2011 at 12:12:04pm
I was under the impression 2 straps is normal, 3 is for heavier duty use, then needing material removed. From what i can tell the fly is bog standard and just factory balanced, there is no recess in the fly for lugs, the reason for the bolt heads sticking up on the diaphragm is due to new spring washers fitted underneath that are a tad thicker original. The thrust bearing doesnt have any locking device and is pressed onto the plunger, both new. Edited by Carlzilla on 17th Jul, 2011. On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 12:22:15pm
Thrust plate, not bearing
17th Jul, 2011 at 12:40:40pm
Ah, i removed the thrust washer and locking spring only this morning for the purpose of removing it all as one piece, i keep thinking the problem isn't lying in the flywheel/clutch assembly. The hydraulic part was bled recently with no air coming out, i have the tinyest amount of play in the master clevis pin, which im happy isnt causing a problem. Im changing the clutch arm to another one now with Craig and im going to give that a shot after adjustment, other than that i really dont know what to try next. On 26th Jan, 2012 Tom Fenton said:
17th Jul, 2011 at 01:55:44pm
All back together, still did the same thing. So i sat in the car furiously pumping the clutch and i slowly got pedal pressure back. So im now thinking hydraulics again? But last time i bled it no air came out... On 26th Jan, 2012 Tom Fenton said:
18th Jul, 2011 at 05:32:23pm
Just thought fuck it, bought a new master cylinder, slave cylinder, and braided hose to go direct from master to slave, new float bowl gasket for my hif44 cos i think thats leaking, new manifold gasket cos i think thats blowing too. Sometimes its nice to throw some money at problems. At least ill have an almost fully rebuilt clutch system by the end of it :) On 26th Jan, 2012 Tom Fenton said:
![]() 384 Posts Member #: 4215 Senior Member |
23rd Jul, 2011 at 05:04:30pm
hi guys...
23rd Jul, 2011 at 05:05:56pm
23rd Jul, 2011 at 05:10:14pm
thats what i thought as i saw bill solis do it on his DVD, but mine wont budge:( |
23rd Jul, 2011 at 05:11:38pm
this every happend to any of you guys? and tricks to get it out. |
