Home > Technical Chat > Intercooler and Install Question
rich at mirage can sort you out with a hybrid, he can get 2 types: one biased towards power, and one for drivability have a chat with him, or something like that
(note updated picture)
MaltaMini
Member #: 510
Malta
So, if I fit this Omex or Emerald ECU - are these based on a crank or flywheel sensor?
Does my crank/flywheel have to be rebalanced after fitting this?
I donated, but somehow didn't get the label! :(
MaltaMini
Member #: 510
Malta
By the way, fantastic job on the piccy greypride! Much appreciated!
my emerald uses a crank sensor, ideally it does need to be balanced after fitting the toothed wheel, mine was
ah that brings me to a question sorry to hi jack....
my engine was balanced when it was built, just say if i were to fit a sensor on the crank pulley, can i get it balanced whilst keeping the original balancing of the engine?
look at this if you want to save some money: http://picasso.org/mjlj/
MaltaMini
Member #: 510
Malta
Interesting stuff regarding the home-built ECU...
What sort of inputs does it need?
Aiflow, Exhaust temp. intake temperature...
as its just controling ignition it uses a crank sensor and a take off on the inlet manifold to plumb into the units map sensor
it uses ford parts and looking at the site if you get a built up unit it wont be too complex to install
