Home > Introduce Yourself > hi everyone
wng691s clubby
Member #: 9252
Cleethorpes
welcome
Done now needs redoing lol
On 11th Aug, 2011 Joe C said:
yeah, on my new engine I'm on about 8.2:1 and ive been putting 19psi in on 97 octane, thats probably pushing it though.
We've been running 22psi on 8.2:1 with crappy fuel. Hoping for a bit more at MITP *smiley*
arron81
Member #: 9561
Purbrook
The guy I bought the turbo of rekons he had it up to 25 psi but only once or twice but don't no wat spec the engine was
arron81
Member #: 9561
Purbrook
hi arron, i run a 1380 with low compression. it is alittle laggie off boost but 25psi is a little too much to handle its dangerouse to say the least especially on the road .......... theres no to engines the same................ anyway a warm welcome to turbominis............once you go turbo you never go back
arron81
Member #: 9561
Purbrook
Yer I thought it would be to much wats the best thing todo with the crank on regrds to hardening, lightening balancing
you dont really need to do anything to the bottom end, as most tubro's arnt revvers, if you can get hold of a proper metty turbo crank they are hardened and seem to last better,
that said I'd always fit ARP's just for peice of mind,
arron81
Member #: 9561
Purbrook
Ok I'll try and find one of them thanks
they are marked CAM6581
arron81
Member #: 9561
Purbrook
That's brilliant thanks
