| Home > Help Needed / General Tech Chat > Torsion bar rear suspension | |||||||
9 Posts Member #: 9629 Junior Member N E England |
14th Nov, 2011 at 10:08:57pm
Can't see the point mate. As well as some oem cars, plenty of F1 cars use torsion bars but these guys have unlimited design and machining budgets. people use coil springs cos they can be bought off the shelf with almost any rate you want.
I used to talk to myself a lot until I realised I wasn't listening. |
15th Nov, 2011 at 09:02:22am
The idea is on the shelf labelled OTD idea no. 635.
15th Nov, 2011 at 10:43:04am
On 4th Nov, 2011 Paul S said:
It could be lighter than a standard rear beam setup. What concerns me is putting all the rear suspension loads onto the healboard. I dont really see how it would be much lighter. The beam would need strengthened around the bar mounts. There will also be two heavy steel bars to create the torsion. And it still needs shock absorbers anyway. And as you say, the floor may need strengthened as the suspension loads are now on different areas of the chassis A lightweight beam and swing arms with a pair of alloy coilovers wont be too heavy ? or indeed the OEM rubber springs So IMO it could actually be heavier, be difficult to adjust or fine tune, you have no spring options without new bars or some adjustable designed in etc. Plus the nightmare of making it work. 9.85 @ 145mph
15th Nov, 2011 at 10:44:37am
Coincidently, article in recent Autospeed
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
15th Nov, 2011 at 12:17:09pm
OEM use torsion bar rear beam because they are much cheaper : less material, less articulations and due fitting.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
15th Nov, 2011 at 04:08:59pm
To the injuneer.
