| Home > Help Needed / General Tech Chat > white smoke at idle | |||||||
8th Aug, 2012 at 01:53:47pm
that compression test didnt get done yet then Edited by Brett on 8th Aug, 2012. Yes i moved to the darkside |
![]() 117 Posts Member #: 9966 Advanced Member Norwich, Norfolk |
8th Aug, 2012 at 02:03:58pm
i didn't do the last build, so can't say for sure (i should have checked), but i've found a lot of bodges on it (cable tie holding the solenoid together, stuff scred through floor, bodged exhaust etc etc), previous owner shall remain nameless as he's a member, but i doubt i'd buy anything from him again.....
8th Aug, 2012 at 02:04:45pm
Brett - beleive it or not, I was driving into town to buy a compression tester.....
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
8th Aug, 2012 at 02:24:41pm
Replacing the head gasket isn't a long job, but if you've not done it before it will always take three times as long.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
8th Aug, 2012 at 03:01:01pm
thanks Mike. |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
8th Aug, 2012 at 05:03:28pm
I think i'm right in saying, you want the BK450 cylinder head gasket if your engine is 1300cc.. Alan Main Build
, atleast half your job is done now no fault finding just fixing :)
