Home > Help Needed / General Tech Chat > Minisport cams
oli79
Member #: 8480
*wink*
On 23rd Oct, 2012 Paul S said:
And a flat cap :)
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Scudy23
Member #: 10087
Very wet south wales
Cheers guys
newman-cams.com explain the different materials used in the manufacture of cams and cam followers.
Newman Cams being one of THE cam manufacturers in the UK other than Kent Cams. I also read somewhere that Piper do not actually grind their own cams, but contract it out to one of the other two. How true that is i don't know.
http://www.newman-cams.com/pdf/camshaftselection.pdf
Scudy23
Member #: 10087
Thats a very source of info for newbies.
Their cams are a good price too..
Minisport do grind cams in house, I have had many over the years some 30 for N/A engines and they were fine!
Sir Yun
Member #: 1592
Smart Guy!
I think it's only us that use the term billet. They seem to use the term "blank".
the term billet is used pretty loosely and probably incorrectly half of the time.
A billet: A small, semi-finished piece of metal that is rectangular, circular, or square in shape. Billets are smaller than blooms. Some definitions refer only to the rectangular variety
So basically a piece of metal.
Nowadays the term billet more or less refers (incorrectly) to something that has been machine cut from a single piece of metal
I.e. take a piece of round bar that is then machined first then hardened , then ground. Or ground and then hardened depending of the capabilities of the maker. ( corvette Ls7 cams are made this way) .
Nowadays a single machine can automatically take a piece of round bar and machine it into a UGL cam that then gets transferred to a CNC grinder. The UGL cam ( un ground lobe cam) could probably be referred to as a blank.
The machine does not care much what it is fed so you can also stick in a forged piece of metal. That has some specific properties that are nice and it eliminates the need for a lot of the machining. You can still only partially machine these and you get a blank/UGM cam just the same.
Generally anything cut from standard section of plate is refered to as a billet.
The fact that cam manufacturers use the term "blank" infers that the cam could be cut from a piece of standard round bar, a forging or a casting.
Given that the A Series cams are supposed to be manufactured from EN34 tells us that they should be billet as EN34 comes from the old BS970 which in my day referred to wrought steels, i.e. round bar.
A great anallergy sir yung, thanks!
Scudy23
Member #: 10087
If thats the morspeed sl13 theres one on ebay for sale with cam followers... £70
On 23rd Oct, 2012 John said:
Mike runs a Morspeed Phase 3 I think? You aren't likely to get another.
