Home > Help Needed / General Tech Chat > Still having problems getting my 1330 going - uploaded video
True, but the regulator would only limit pressure....so as the pump will never cause too much, then it is basically just being used as a filter really.
But of course it only takes a minute or two to try it without.
But again....are the plugs getting drowned, or are they dry ?
Of course, timing could be out too. Too far retarded could cause poor starting.
kappa
Member #: 9854
Hounslow, Middlesex
I will need to give all these things a try, first without the fuel reg, then check the plugs and finally timing again.
Hopefully will sort it out, will be doing some work tommorow
