| Home > Help Needed / General Tech Chat > Compressor blowing fuses | |||||||
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
7th Feb, 2013 at 09:09:08pm
What size breaker is tripping at the fuse board? I.e 16A? 30A? |
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
7th Feb, 2013 at 09:22:20pm
Shouldnt make any difference, the hose outlet to tools and the safety valve(yellow in pic) are on the same ports anyhow as they come from the tank, as long as you didnt move the small tube between the non return and the switch, it is this that unloads the larger tube when the switch operates/or is operated by the red knob on top. Even so this is only to allow the motor to start turning, they are still regarded as a high starting torque application as opposed to a low starting torque say a circular saw for example.
On 7th Feb, 2013 apbellamy said:
I'll get one tomorrow. Top work on the picture. Confession time - I swapped the blow off valve and the hose connector bit onto the other side of the switch. It ran fine and got up to pressure a few times after that. I'll double check that I put the pipe back on right from the non return valve properly. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
7th Feb, 2013 at 10:06:33pm
On 7th Feb, 2013 evad1980 said:
What size breaker is tripping at the fuse board? I.e 16A? 30A? On 18th Oct, 2013 apbellamy said:
7th Feb, 2013 at 10:35:45pm
Oh... That's strange, the 13A cartridge fuse can't take the load? Well it sounds like a fault with the appliance then. If it is manufactured with a 13A fuse then it should be sufficient for the compressor.
8th Feb, 2013 at 08:19:42am
Yes, wiring is good and the lead to the unit isn't damaged.
8th Feb, 2013 at 09:19:46am
Yes, forgot that, the capacitor could be faulty. Depends on the notor as to whether there is a start capacitor or a run capacitor or both. A start capacitor will usualy have a start relay to drop out the start capacitor and start winding.
Edited by Sprocket on 8th Feb, 2013. On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2013 at 05:56:26pm
Tried it with the feed to the one way valve disconnected. lasted maybe two seconds then popped the fuse.
8th Feb, 2013 at 06:02:27pm
Nail time! If something is worth doing, it's worth doing half of. |
8th Feb, 2013 at 06:07:08pm
Bet there's shit loads of fuses in the house lol, have you disconnected the capacitor ? Edited by oli79 on 8th Feb, 2013. On 18th Oct, 2013 apbellamy said:
8th Feb, 2013 at 06:13:03pm
It's got crimped terminals on it and I'm a bit CBA at the moment.... On 11th Feb, 2015 robert said:
8th Feb, 2013 at 06:28:15pm
What type of circuit are you running in your garage? Is it a ring or a radial? Do you have a fuse box in your garage? |
8th Feb, 2013 at 07:01:27pm
I was just doing a bit of googling as I'm interested in the problem myself.
8th Feb, 2013 at 07:14:57pm
The garage is fed from a C rated breaker in the cellar. Big chunky cable runs out to the garage supplying a lighting ring and a socket ring. Not using an extension lead.
8th Feb, 2013 at 07:28:47pm
Ya I can understand that... If you could get a higher rated Bs1362 fuse I'd say that would sort it but they only go up to 13A.
8th Feb, 2013 at 07:34:59pm
I reckon something has broken in it. It worked fine when I first tried it. On 11th Feb, 2015 robert said:
8th Feb, 2013 at 08:15:05pm
As a qualified Electrician please allow me to clear this up before someone does something potentially dangerous from missinformation.
8th Feb, 2013 at 08:41:19pm
On 7th Feb, 2013 Sprocket said:
30 amp supply for a 13 amp applience?! My arse......... Might as well jam a nail in there and not bother with the fuse altogether. Sorry Colin but yes... Not the fuse, as I said, the supply. It's a simple fact that large "single phase" induction motors draw large start-up currents. They are not really single phase as the capacitor deals with the phase shift for the second winding (start-up or continuous) but the start current is high. 13A fuses may be HRC but thy will blow after a second or two if a 3HP induction motor hasn't got up to speed. A 3HP motor will draw at least 25-30A whilst running up. If the supply to the socket isn't good, there will be a massive voltage drop which slows the start-up and hence the longer than normal start-up blows the fuse. It may not be Andy's problem but I would always use a very highly rated cable (4MM^2 or more) to the 13A fused outlet. Schrödinger's cat - so which one am I ??? |
8th Feb, 2013 at 08:42:04pm
Well put oli. |
8th Feb, 2013 at 08:47:28pm
Maybe my idea was 'wank'... However, not dangerous.
8th Feb, 2013 at 08:53:14pm
Ok Bud Wank is probably not the best term and it was in no way designed to offend, but dangerous it is, unless the motor cable was already designed/changed in order to be sufficiently rated for a larger 16 Amp supply then under a low fault condition it could cause a fire, its the whole reason we have bs7671.
On 8th Feb, 2013 evad1980 said:
Maybe my idea was 'wank'... However, not dangerous. On 18th Oct, 2013 apbellamy said:
8th Feb, 2013 at 09:07:35pm
My understanding was that the 16A breaker would trip long before the flex would overheat and burn if the compressor pulled too much current under a fault condition.
8th Feb, 2013 at 09:22:08pm
Look were getting way o/t and there are reams and reams of ac theory and waffle that can be thrown in here, hence why it took me 3 years at college.
8th Feb, 2013 at 09:27:08pm
Anyhow to lighten things here is an image of what it will run like when repaired
8th Feb, 2013 at 09:49:14pm
Well it wouldn't be a good thread unless we went off topic...
9th Feb, 2013 at 08:41:50am
Oh dear, what have I started. I never though Oli had a serious side to him... On 11th Feb, 2015 robert said:
