Home > Help Needed / General Tech Chat > Lambda question??
I thought it might be the 'flats' on the "HIF" adjuster screw? 4-off, 90 degrees apart?
Edited by turbodave16v on 17th Aug, 2005.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
arrr those nasty old SU HS carbs LOL
alex
AlexF
Turbo Tel
Member #: 588
Delaware, USA
Yup you got it, on the SU there was a nut underneath which adjusts the jet height, six sides so 60 degrees per flat.
So whats on the HIF? knurled nut?? how do you adjust it? I have got hold of a turbo engine but its still in UK so havn't seen it yet.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
mixture screw... moves the jet up and down via a lever (bimetalic).
Alex
AlexF
turbo hogster
Member #: 178
stowmaket suffolk
ive alreadey got a sensor hole in my elbow from the turbo what type would i need for this application, at the moment of got a gaffed one fitted.
if i bought a new one i could then use i multi meter to read it.
yes you could mate
All sensors are not the same. Most narrowbands are comparable though.
Until you have driven and tuned a car with a wideband, you simply cannot appreciate how good they are.
They cover such a wide range of AFR's, as different fuels have different AFR's for stioch, max power, cruise etc Petrol, LPG, diesel, Methanol etc etc
Lead kills these sensors. Most other fuels are fine.
For Turbo Tel.
I would never run a turbo car at an accurate 12.5:1 AFR, let alone guessing with a narrowband. That is so borderline on meltdown it simply isnt worth the risk. I'd always aim for high 11's with a wideband.
Using a narrowband is better than nothing, but as the output voltage can also change with EGT, and such a small voltage change represents a massive AFR change, trying to tune anywhere close to lean for max power is very dangerous.
If you do your own tuning, spending £200 or so on a wideband will be some of the best moeny you have spent. Having it installed full time in the car gives so much peace of mind at all times, and also allows you to get a full picture of whats going on, for when you want to make changes.
