Home > General Chat > Wheeey! Got into the 13's this morning!
steve1275
Member #: 951
Bromsgrove
Well done! But be warned,you get hooked on this stuff,even when you're old enough to know better......... *Yes*
'Where does the engine go?'
steve1275
Member #: 951
Bromsgrove
oops!
Edited by steve1275 on 18th Aug, 2013.
Already properly hooked Steve.
One bit of criteria holding it back is the fact that I want to use it on the road still.
I drive to every event and have only been trailered home once. So not bad.
well done gary a mega achievement.
Fantastic!!!
eden7842
Member #: 8852
leicestershire
I agree with you gary. I drive mine all the time
Well done.
There is something very satisfying about driving the mini to an event, it surviving and then driving it home.
Edited by minimole23 on 18th Aug, 2013.
Good effort mate.
jamiestevenbell
Member #: 9941
Derby
What power are you running to get that time?
It's near enough a full weight car. Just lightweight seats and boot lid. And makes around 200hp at 20psi.
Funnily enough. My best run was on about 16-17psi.
It really isn't just about lots of power.
Edited by theoneeyedlizard on 19th Aug, 2013.
eden7842
Member #: 8852
leicestershire
Of the line is key. I gained half a second by letting my tyres down!
What diff and f.d are you running?
steve1275
Member #: 951
Bromsgrove
It's all about the 60ft time,especially with fwd.
Open diff, 3.44:1, A048R's at 15psi.
steve1275
Member #: 951
Bromsgrove
Try 12psi,burn out in the box long enough to see the tyre smoke,then let the brake off and keep the wheelspin towards the start line,otherwise you pick up other people's crap.
supermotolee
Member #: 2153
kings langley
With an open diff does it spin both wheels doing a burnout?
Nice one Neil!!
T3Tone
Member #: 252
Sunny suffolk
Congratulations, great achievment
-MINI CLUBMAN 1380 TURBO-
Top work mate, I used to say the same lolol now I have a AA gold card.
I've got HIC rescue. I'm not that brave.
Used the 3 times. Once from Santa pod and twice from Uncle Rays Rollers.
eden7842
Member #: 8852
leicestershire
Lee. Mine span both but was on rele affecting one tyre.
When I got back from mitp my passinger flitch was coverd in rubber and not a bean on the drivers
