| Home > Help Needed / General Tech Chat > I give up | |||||||
32 Posts Member #: 2150 Member |
30th Aug, 2013 at 10:02:36am
If I was you alex, I'd send it back now unopened an see if you can get your money back. |
78 Posts Member #: 9073 Advanced Member Edinburgh |
30th Aug, 2013 at 12:35:15pm
Rich, did you ever run the car with the sensor un-powered?
30th Aug, 2013 at 11:36:45pm
No Nial never got as far as firing it up, the sensor needs the heater calibrating first and then a free air calibration. All before you start the engine. Was also very careful with the sensor, it's not been dropped or thrown against the wall in disgust lol |
174 Posts Member #: 9128 Advanced Member |
31st Aug, 2013 at 08:04:52pm
Well I ordered my vems wideband with EGT, the other afternoon and it arrived the next day within 24 hours (TNT).
31st Aug, 2013 at 09:59:57pm
yeah, its fine to use without the EGT, in fact you can configure it so the start up read out is somthing else like ambient temp, or cycle through with the button. On 28th Aug, 2011 Kean said:
31st Aug, 2013 at 11:18:33pm
Didn't know that cheers joe, I'm gonna use the EGT just need to make a boss to fit it. Then decide where it's gonna go, from the reading I've done. Looks like my best options in the LCB's collector. Not as accurate but surely, your looking for the temp difference between different settings anyway ? So shouldn't really matter, unless comparing it with other cars temps. Edited by DILLIGAF on 31st Aug, 2013. |
326 Posts Member #: 1323 Senior Member |
4th Sep, 2013 at 07:46:31pm
On 29th Aug, 2013 carl talbot said:
Press the XD-16’s button three times. “CAL” will begin flashing on the XD-16 display. Press the XD-16’s button one more time to confirm the Free Air Calibration command; “CAL” will no longer flash and the XD-16 will send the command to the LC-1 ? I just did this today and problem sorted - all working fine Remember, you must remove the lambda sensor from the exhaust and hang it in free air first [ the original issue was caused by one of the connectors on the wire between LC-1 and XD-16 coming loose while the unit was powered up] |
