Home > Help Needed / General Tech Chat > Anyone know we're to buy carbon fibre rocker cover?
How about drilling some holes in the rocker cover. That should lighten it quite a bit.
jonny f
Member #: 9894
Dorking
you still have a rear subframe?
enne
Member #: 9827
Germany
Done also some... but still in development!
Also have to do a new mould. Have to do some improvements.
F415dda
Member #: 10595
Pembrokeshire,Wales.
Yeah it's cut to pieces now tho.
more speed 1293 turbo mini-180bhp 171tourque@15psi
best 80's mini at mini fair 2-2013 British mini fair 2014- runner up best 80
Top ten winner at players classic goodwood
Top 55 winner @imm2014
Runner up 80's @minifair 2-2014
Auto finesse sponsors choice award @ultimate stance 2014
mini fair best 80's winner 2015
F415dda
Member #: 10595
I have carbon fibre doors,carbon fibre roof skin,carbon fibre one piece front end,carbon fibre 1 piece bootlid,carbon fibre boot floor,custom 4.5 gallon tank,full stripped out interior,poly carb windows,removed rear seat and door pockets,drilled rear subframe,miglias front subframe so much more than"just drilling some holes"cheers
On 16th Sep, 2013 Sprocket said:
On 16th Sep, 2013 F415dda said:
Yeah haha,Endaf is drilling front and rear subframe and will be replacing bolts as well .
On 15th Sep, 2013 madmk1 said:
I know the car, he calls it the " mad max car" Have you swaped any of your bolts? To Ti?
If you're looking at competing with the likes of the DON or Paul Wigintons car you'll need to do more than drill a few holes in the subframs or replace a few bolts
Not the point I was making. If you don't know where to look to loose that weight, you need to 'think outside of the box'
For example...... and I'm only going to throw a couple examples at you....... outer CV joint, counter bore the centers...... Tubular driveshafts.......
Chris-G
Member #: 10229
Stroud
How about lets give the chap some advice on how to lighten his car rather than take the piss out of him/knock him. After all, he did ask for advice to begin with.....
He isn't taking the piss he is giving him very very useful information for lightening his mini. I recived the same from paul w in a conversation we had a while back, took another 3kg off that evening.
I applied the same principles to my metro, it is under 800kg now and still is full steel with glass all round. I still can use fg parts and plastic windows.
redrat
Member #: 9107
Devon
I saw F415dda 's mini at coombe , was very impressed with the weight saving but sprocket is right I also looked at madmk1 's mini at riv run , every nut & bolt was either drilled or titanium , both have different ways of saving weight but if you combine them I'm sure you would be one of the lightest !
Still overall top car F415dda. Was very impressive *smiley*
I also saw it at Combe, although I can appreciate the cost and time gone into this build, It just isn't my cup of tea, But, each to their own!
