Home > General Chat > Oh no!!
I have a 1275 pre A+ transfer case and possibly idler in the shed somewhere.
There you go, you only need the pre A+ primary gear now
Primaries are the same aren't they?
tooth count and profile are very different
Baz_rsp
Member #: 10521
Aberdeen
sorry I was meaning the laygear.
On 29th Dec, 2013 apbellamy said:
On 29th Dec, 2013 Baz_rsp said:
I think I might replace the layshaft
Why? It's the lay gear that are worn. The clue to it's condition was in the description - suitable for rebuilding.
I think I will resell the box and buy the right box, it serves me right trying to save a few pounds.
So if any one wants it pm me, just want my money back.
Baz
Flat oot like a dukes fit!
Baz_rsp
Member #: 10521
Aberdeen
just seen this box on mk1 forum for £800
I was going to suggest trying the Mk1 forum, thats probably the best place to shift it, failing that stick it on ebay
Alex
Member #: 1851
Woolavington, Zummerzet
You need to modify the floor when fitting a remote gearbox to a rod car - the hole in the tunnel needs moving backwards by about ½" and you need to fabricate mounts for the gearlinkage.
I'm interested if you decide you can't or don't want to use it.
