| Home > Help Needed / General Tech Chat > Kad vented 4 pots fitting | |||||||
10th Mar, 2014 at 07:29:12am
Pictures? On 11th Feb, 2015 robert said:
10th Mar, 2014 at 11:13:03pm
Need to take some... I will do when the calipers are connected...
15th Mar, 2014 at 01:24:44pm
oh balls, I need some custom spacers....
23rd Mar, 2014 at 05:45:06pm
FFS....
23rd Mar, 2014 at 06:33:46pm
One hose will be deeper than the other, have you checked both? |
23rd Mar, 2014 at 06:47:31pm
On 23rd Mar, 2014 graemec said:
One hose will be deeper than the other, have you checked both? I can see why you would say that, but I am unaware of any difference (runs to check) and I have fitted at least 4 pairs of these. Could I have been that lucky? then why can I not win the lottery...... lol well wouldn't you know it..... http://minispares.com/product/Classic/Brak...k%20to%20search so now i know where all my luck went......... Edited by Sprocket on 23rd Mar, 2014. On 26th Oct, 2004 TurboDave16v said:
23rd Mar, 2014 at 06:49:56pm
yep I checked they are both the same, I guess these have been put togther by someone thinking they will fit becasue the fittings have the correct thread.... rather than fitting the vechile in question..
23rd Mar, 2014 at 07:28:58pm
Sprocket, you may have used longer tube nuts if you've made you own pipes up, in which case they'll probably work if you had a pair of non-specific hoses with deeper threads on both sides. |
28th Mar, 2014 at 07:18:47pm
now I'm confused the new hoses from minispares have arrived and they are both the same, so no smaller one. They both have the same part number and are identical to the ones from ebay except for the fact that they come with copper washers for the calliper end.
29th Mar, 2014 at 08:19:37am
I'm pretty sure that the oem and the copper replacement front to front brake line i have both have the longer nut on them.
29th Mar, 2014 at 08:50:17am
I've had to cut the banjo bolts down on mine as I've split my front circuit at the bulkhead and don't have the splitter thingy above the driver's side brake hose where it pops through the subframe. On 11th Feb, 2015 robert said:
29th Mar, 2014 at 06:41:11pm
ok I'm the dick.
29th Mar, 2014 at 06:50:21pm
get them bedded, the fibry top layer of the new pad (some look like a fooking carpet!) can ad a lot of squishyness
29th Mar, 2014 at 07:34:32pm
Also, wedge the pedal down overnight and then bleed them again. They usually get a bit firmer. |
29th Mar, 2014 at 07:58:28pm
thanks guys, no bleeding tomorrow, going up to do the mother day stuff...
31st Mar, 2014 at 09:34:16pm
I have left the car for 2 days and let everything settle. I jacked the back up made sure the shoes were adjusted and re- power bled the system. I got some more small air bubbles out and I now had the same firm pedal that I had with the old brake setup.
21st Jul, 2014 at 09:30:21pm
well I word springs to mind Squeak...
21st Jul, 2014 at 09:39:31pm
Do they stop though? that is all that really matters On 26th Oct, 2004 TurboDave16v said:
21st Jul, 2014 at 09:44:27pm
true :) I run a supercharger and I don't care the TB is on the wrong side.
21st Jul, 2014 at 09:45:25pm
Back of the pads got a good coating of CopperSlip? |
21st Jul, 2014 at 09:49:40pm
they had a special sticker.... maybe the metro 4 pot spring kit might help.. I run a supercharger and I don't care the TB is on the wrong side.
21st Jul, 2014 at 10:09:59pm
Ah! Are they mintex pads?
21st Jul, 2014 at 10:13:48pm
yep the mintex pads I run a supercharger and I don't care the TB is on the wrong side.
