| Home > Help Needed / General Tech Chat > Under fuelling possible over 3000rpm? | |||||||
102 Posts Member #: 5814 Advanced Member Kidderminster |
8th Jun, 2014 at 03:11:53pm
Okay something I've just found. From the plenum to the pressure regulator should there be fuel in there? Daft question it's gonna sound I know as my thoughts were it's just for sensing purposes?? More Boost, More FUN! |
8th Jun, 2014 at 03:13:30pm
Try blocking the part throttle lean off pipe. It goes from the side of the carb up to the top near the flange on the manifold side.
In the 13's at last!.. Just |
8th Jun, 2014 at 03:20:56pm
The loop from the top by the inlet manifold to the one on the side by the fuel in on the carb? More Boost, More FUN! |
8th Jun, 2014 at 03:34:19pm
By the way it's not coming through it at great pressure just dribbling through it. And if it is that link pipe. No good it's still doing it More Boost, More FUN! |
8th Jun, 2014 at 03:54:46pm
May be nothing to do with this but I have had an EDIS that refused to work properly over 3000rpm. |
8th Jun, 2014 at 04:02:20pm
Well seems to me is a fuel issue as it will go all day flat out however now it's like when you come off the throttle it's still fuelling? Which is why I rebuilt the carb as I thought it might be the needle seat not shutting off. No good though as the problem is still here. And now I've noticed as I said above there is a constant dribble from the regulator into the plenum. Hence why that keeps filling up with fuel? More Boost, More FUN! |
11th Jun, 2014 at 06:27:29pm
Right some good news!!! Fitted new fuel pressue regulator and yay the over fuelling into the plenum has gone. Drives a treat now just needs fine tuning so I know it's okay on boost. Although I can't get 3-4 psi to show at the regulator. I have a gauge and I'm right in thinking you put it between the carb and the regulator. Is that right? Also where is the best place to fit the lambda for an afr?
11th Jun, 2014 at 11:40:56pm
yess to check fuel pressure you place the gauge after the reg ie remove the line feeding the carb and stick the gauge in there turn the pump on should be 3-4psi as you already know
