Home > Help Needed / General Tech Chat > NoDIZ map??
t@z
Member #: 452
Chester, UK
should be on your box or on a sticker on the back of the device
www.twitter.com/lilpinkiy
coopdog
Member #: 9628
thank you for the help *happy*
where could i read up more about tunning the map to get it right aswell?
supermotolee
Member #: 2153
kings langley
First you need to calibrate the sensor with a timing light or whatever map you run won't be correct, so to do this with the megajolt u just unplug it and the edis runs the engine on a set 10 degrees and then you check with the timing light that you are actually getting 10 degrees if not you either have to move the sensor or adjust it on the software, with your nodiz you may have to just manually fill the table in so the entire thing is all 10's as you do not run an edis, this has to be done before you worry too much about maps as you could be a few degrees out and whatever map you try and run will be out of sync
coopdog
Member #: 9628
ok that sounds good :)
thank you
