| Home > General Chat > Nodiz Map | |||||||
![]() 330 Posts Member #: 9628 Senior Member |
28th May, 2014 at 05:15:41pm
On 28th May, 2014 mini118118 said:
well here it is..
I should just mention that this has been bast*rdised into a Nodiz map and has dirived from MR Benross's Map.. Runs really well for me at 8psi going to use this one and put it on the rollers, need to get my needle reprofiled too..... whats your spec? |
28th May, 2014 at 05:17:45pm
also any chance you have it the nodiz* file so i can just load it in instead of typing it all out? :L |
28th May, 2014 at 05:30:39pm
I am surprized that no one has really thought why there are very few ignition maps freely available.
87 Posts Member #: 10069 Advanced Member |
28th May, 2014 at 05:55:11pm
Ok sprocket point taken.. I have removed the map....wasn't meant to cause any issues or do anyone out of money,misguided or mislead just trying to help people with the minefield of Mapping...... coopdog PM me your email... |
28th May, 2014 at 06:36:23pm
yeah i do find the nodiz guys a bit weird, you ask certain questions and they answer it straight away, other times they dont even bother. its weird, im having second thoughts taking it to them to have it RR now |
28th May, 2014 at 06:44:03pm
Was that matt bloke not no here? I have started posting on Instagram also my name on there is turbomk1golf
28th May, 2014 at 06:48:54pm
On 28th May, 2014 madmk1 said:
Was that matt bloke not no here? yeah he was at one point, havent seen him in awhile |
62 Posts Member #: 10207 Advanced Member |
12th Jun, 2014 at 02:12:24pm
The converter is now ready :)
Edited by mtechmatt on 12th Jun, 2014. |
12th Jun, 2014 at 02:17:37pm
If you download V1.7, then goto 'Import MJ map' in the file menu it will first stretch the RPM and LOAD cells, then fully interpolate the map to fill the blanks.
12th Jun, 2014 at 04:32:27pm
I've only recently bought a nodiz why is my serial number 5039, have you sent me an old unit? |
12th Jun, 2014 at 04:58:04pm
The serial number is based on the bluetooth module, You bought yours 4 months ago the change over was approx 2 months ago. If yours has the 5500 firmware then it is in the cross over.
