| Home > Help Needed / General Tech Chat > Lean when setting off | |||||||
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
2nd Jun, 2014 at 11:31:10am
On 2nd Jun, 2014 Rob Gavin said:
interested in the findings Lee; I'm experiencing similar issues What the mind can conceive the mini can achieve
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
2nd Jun, 2014 at 01:39:34pm
Mine tends to lean off when i am spanking it in 4th but perfect else where. |
2nd Jun, 2014 at 02:51:50pm
On 2nd Jun, 2014 lee.pb said:
Is that the low pressure or lean off ??????? On 2nd Jun, 2014 Rob Gavin said: interested in the findings Lee; I'm experiencing similar issues |
2nd Jun, 2014 at 05:24:12pm
I have the lean off issue too, just at the clutch biting point the mixture goes lean and the engine is weak sauce at this point. A rev and dump of the clutch gets you over this but sounds like your a bit of a learner. On 7th Nov, 2008 Nic said:
336 Posts Member #: 9941 Senior Member Derby |
2nd Jun, 2014 at 06:31:19pm
Must be a common issue then mine seams to go very lean on lift off, is this normal? And what's an acceptable figure to see on my afr gauge at idle as I know mines lean Edited by jamiestevenbell on 2nd Jun, 2014. |
3rd Jun, 2014 at 06:42:43am
James mine sits between 13-14 at idle.
3rd Jun, 2014 at 09:32:42am
Jay that is exactly what mine does and its driving me mad - as well as making me look a right pillock in traffic.
3rd Jun, 2014 at 02:58:11pm
Are we all running the lean off pipe connected ?
3rd Jun, 2014 at 03:01:43pm
my lean-off pipe has been blocked off |
3rd Jun, 2014 at 03:28:25pm
Mines connected so will try it both ways and see what the outcome is.....
On 3rd Jun, 2014 Rob Gavin said:
my lean-off pipe has been blocked off What the mind can conceive the mini can achieve
3rd Jun, 2014 at 05:18:30pm
Lean off blanked off from first start. |
3rd Jun, 2014 at 05:27:19pm
My lean off was connected, I blocked it to see but no difference. Mine goes lean enough to go off the scale on the wideband. If I polish the needle to try and get a bit more fuel in that area it gets a bit too rich at idle. I thought it might be caused by an intake manifold leak so was going to investigate that plus play around with dash pot springs and damper oil weights. On 7th Nov, 2008 Nic said:
4th Jun, 2014 at 07:23:32am
Hopefully will get to have a play over the weekend with this issue.
