Home > Help Needed / General Tech Chat > Lambda v's AFR
On 6th Jan, 2021 robert said:
e5, i have noticed on the dyno tailpipe reading being a little leaner than downpipe reading , i put thsi down to the ex gases changing a little as they complete burning as they go down the pipe .
regards
Even a minor exhaust leak or two will change exhaust gas composition. A leaky back box can be the difference between a pass or a fail on the MOT analyser!!...
If you can smoke test the exhaust system, that’s probably the easiest way to see how leaky the exhaust is.
