| Home > Help Needed / General Tech Chat > Turbo/dump valve fluctuating noise :/ | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
18th Nov, 2014 at 08:10:27pm
sounds rather cool though you can do anything if you set your mind to it...
![]() 61 Posts Member #: 6135 Advanced Member bristol |
19th Nov, 2014 at 09:33:24pm
I think im guna drill and tap the manifold that seems to make sense il let you guys know what the outcome is.
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
19th Nov, 2014 at 09:41:11pm
Honestly just change the pipe to start with to eliminate that, anything other than silicone will just collapse.. and obviously dont drill and tap with it on On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
19th Nov, 2014 at 09:52:22pm
https://www.youtube.com/watch?v=xy9YJC8SCak...xv4FiYqx2K0kLvg
Edited by Brett on 19th Nov, 2014. Yes i moved to the darkside |
19th Nov, 2014 at 10:02:53pm
On 19th Nov, 2014 Brett said:
https://www.youtube.com/watch?v=xy9YJC8SCak&list=UUH_PyHwPxv4FiYqx2K0kLvg i like the sound
https://www.youtube.com/watch?v=ZUuW6H2V2T4...K0kLvg&index=17 i keep meaning to grab an updated video @ 18psi ![]() you can do anything if you set your mind to it...
20th Nov, 2014 at 12:49:43pm
yeah il do this at the same time :) and yeah lol i will take the inlet off dw defo dont want swarf getting in that would be a dissaster javascript:void(0)
On 19th Nov, 2014 D4VE said:
Honestly just change the pipe to start with to eliminate that, anything other than silicone will just collapse.. and obviously dont drill and tap with it on |
19th Aug, 2015 at 07:52:16pm
I know it's been a while but thought I would update with the fix :) as was suggested by a few of you guys it was the wrong take off from the carb. Instead I have taken the vacume from we're the servo takeoff come from in the middle of the manifold. It works a treat now and I have the noise I have always wanted since I was a kid :) il try get a vid up soon |
19th Aug, 2015 at 07:55:46pm
http://s1085.photobucket.com/user/yastra/m...ndpo4j.mp4.html
19th Aug, 2015 at 08:33:39pm
Blimey you must of been busy or been enjoying the sound for a year.. haha.. glad it fixed tho, vid wouldnt let me load On 24th Oct, 2015 jonny f said:
19th Aug, 2015 at 09:00:33pm
Haha yeah I have been working away on my placement year so haven't had much time back in Bristol to work in the car :/ although since then i have fitted coilovers, few new additions to the cage, some fibre glass seats and pedal bias box :)
