| Home > Help Needed / General Tech Chat > front drums to disc | |||||||
28th Jan, 2010 at 09:21:12am
On 28th Jan, 2010 apbellamy said:
I believe the bean tin ones are all the same so could be used fo brakes, but am preprared to be corrected ![]() IIRC the tin cans are in a different orientation on each (to space the reservoirs apart) and the brake one has an extra valve arrangement inside which the clutch doesn't have.. But that is from memory so I too stand to be corrected
28th Jan, 2010 at 09:26:30am
What am I on about. Don't buy his. I have an 'as new' clutch cylinder that you can have for the cost of a bacon butty On 11th Feb, 2015 robert said:
28th Jan, 2010 at 09:30:29am
Brake & Clutch master cylinders are different as you state Rod. If something is worth doing, it's worth doing half of. |
28th Jan, 2010 at 09:41:54am
and have a different size bore. clutch are slightly larger at .75 brakes are .70
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
28th Jan, 2010 at 09:58:04pm
Cheers for all the help chaps! its really appreciated!
the pissed up clown stood back up, did a twirl and left bollock naked, |
30th Jan, 2010 at 08:11:18pm
I've had my head in the engine bay of a mini with twin baked bean tin master cylinders today. The brake cylinder is aroudf 1/2" - 1" taller than the clutch cylinder, so I'm guessing they are not interchangable. On 11th Feb, 2015 robert said:
30th Jan, 2010 at 08:55:19pm
Really? Mine look the same size.
31st Jan, 2010 at 07:48:04am
I was looking at a 71 clubman so....
