| Home > 998cc > Head Gasket for 998T | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
28th Oct, 2010 at 05:13:59pm
So I have the same composite (modern) head gasket.
Edited by alpa on 29th Oct, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
28th Oct, 2010 at 08:53:00pm
where is the thread about your trackday ? Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
29th Oct, 2010 at 01:46:34pm
On 28th Oct, 2010 Advantage said:
where is the thread about your trackday ? No thread. I've got no pictures, my daughter was so excited to be in the car that she just forgot to take any picture :) . std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
22nd Feb, 2011 at 10:58:50am
On 10th Sep, 2010 wil_h said:
I thought that I should update this thread with my experience of the 'new kid in town gasket' Basically I have now had two failures of the new gasket, one after a few thousand miles, one after a few hundred, so the first failure: After lunching a copper gasket when I had boost control issues and lots of det I put one of the black ones on, this was just before Le Mans. I was running around 8psi, no pinking, no overheating, a nice relatively unstressd life for a head gasket. It then failed catastrophically. You can see the photo below. Now, it has to be mentioned that I had torqued the head to 68Nm (as standard) but the gasket packet specified staged torquing 20Nm, 40Nm then 54Nm. The following photo shows another firering with damage and likely to fail soon: I therefore put this failure down to me over-torquing the gasket. So, on to the second failure. This time I torqued to 54Nm in stages as specified. The gasket failed, with a leak from cylinder to coolant, see photo: Now, having experience of this type of failure I know it's owing to under-torquing. I calibrated my wrench last month by the way, but it's unlikey to be high at 68Nm and low at 54Nm in any case. I'm not suggesting that this gasket is a pile of junk, just it may not be suitable for the extra heat and pressure of a turbo engine. My advice is that the Copper type (that are half the price) are more than up to the job and I wouldn't suggest using the Black type. I'd be interested in others experience. It is worth noting that these gaskets are not in any way the same as the BK450 in material or construction and that the fire rings on the copper gaskets are actually thicker. I hope this is of use to some. Wil, Did you conclude that these gaskets are no good or find another reason? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Feb, 2011 at 11:03:44am
Well I have had other head gasket failures with the copper ones. But they have all be det related owing to one thing or another.
22nd Feb, 2011 at 11:06:45am
Thanks, I'll stick with copper for the new engine then. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 568 Posts Member #: 1200 Post Whore Bristol |
7th Mar, 2011 at 09:22:10pm
any suggestions for using a 1275 head on the 998? I remember MRA doing a headgasket a while back and something mentioned on minispares. |
7th Mar, 2011 at 10:03:32pm
Use the BK450 for that set up. Is is only the 998 on 998 gasket that is problematic. http://www.twin-turbo.co.uk
55 Posts Member #: 909 Advanced Member |
9th Mar, 2011 at 04:39:10am
Someone posted earlier that one can NOT use a 1275 head gasket with a small bore head and small bore block-- hogwash. I've done it and the car is still running the same gasket to this day. Someone had pocketed the block for a 1275 head. The pockets were into the fire ring on a small bore gasket but ok on the large bore gasket. You DO need to pay attention to one coolant passage, but you can either nick/file the gasket a bit or chamfer the hole in the block or both. But it WILL work in a NA car (it is not turboed so can't speak to that, but I don't see any difference).
9th Mar, 2011 at 08:01:13am
That seems odd to me. On all the 998 heads I have, the fire ring on the 1275 gasket overlaps a water hole, so all you do is fill two cylinders up with water.
On 9th Mar, 2011 Spank said:
Someone posted earlier that one can NOT use a 1275 head gasket with a small bore head and small bore block-- hogwash. I've done it and the car is still running the same gasket to this day. Someone had pocketed the block for a 1275 head. The pockets were into the fire ring on a small bore gasket but ok on the large bore gasket. You DO need to pay attention to one coolant passage, but you can either nick/file the gasket a bit or chamfer the hole in the block or both. But it WILL work in a NA car (it is not turboed so can't speak to that, but I don't see any difference). . Fastest 998 mini in the world? 13.05 1/4 mile 106mph
27th Sep, 2011 at 03:48:05pm
Still using my car with this composite gasket, no known problems. I must have done at least 10000km since I installed it. Including engine mapping, 1/2 track day and regular full boost accelerations. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
20th Apr, 2012 at 11:22:59am
Anyone else got any long term experience of these black composite 998 head gaskets?
20th Apr, 2012 at 06:49:31pm
I have one of these on my car now. It seems ok so far but it's only done about 300 miles.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
20th Apr, 2012 at 07:34:32pm
would that be the crewes missiles day? if so i'll see you there.
On 20th Apr, 2012 gr4h4m said:
I have one of these on my car now. It seems ok so far but it's only done about 300 miles. The details in the gasket did quote a lower nm figure than the book... I can't remember which one I went for in the end. The coppers did seem to seep a bit of water this one hasn't so far. It's getting a thrash on the rollers tomorrow so we will se how it holds but then I have limited boost... one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
