| Home > Help Needed / General Tech Chat > CAMSHAFT CHOICE | |||||||
263 Posts Member #: 115 Senior Member Austria, near Vienna |
3rd Oct, 2004 at 07:34:28pm
I am using the 274i cam with 1,5 rockers.
Bimmer Twinky headed and turboed A-Series:
3rd Oct, 2004 at 07:49:15pm
Turboharry...
3rd Oct, 2004 at 09:41:11pm
just to knock every thing right out of the window on cam choice t3tone has just got 150 bhp at the flywheel running 10 psi with intercooler but wait for it , running a 276 kent on 1.5's.
3rd Oct, 2004 at 09:42:33pm
Seems to be a lot of variation, which can only be a good thing on the quest to pick a good cam |
4th Oct, 2004 at 07:26:01am
I have not had any problems with 1,5 rockers over the years. Well, the only exception being my 970S engine with 8-port head. It would have run better with lower ratio...
4th Oct, 2004 at 11:31:27am
On 03/10/2004 17:24:44 dan said:
Thought i'd see if anyone has had any experience with this cam I spotted on the Kent Cam website:- Kent 274sp Sports Torque, Power Band 1500 - 6500, Cam Lift 7.23mm Inlet 7.13mm Exhaust, Valve Lift 8.85mm Inlet 8.71mm Exhaust, Duration 248 / 274 Degrees, Timing Figures 16/52 71/29, Valve Timing 108 Degrees I make the cam duration a 248 / 280... anyone else? AlexF |
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
5th Oct, 2004 at 09:56:11pm
use it on the mpi with the m45 s/charger no probs 132 bhp(5200 rpm) on the rollers but torque only 135 ft lbs @3900 - it is only a 1275 cc - also on 1.5 rr , tried standards didn't seem to make much difference drivabillity or power , which probably indicates something else is a limiting factor |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
6th Oct, 2004 at 07:02:29pm
I have been doing some thinking about my M45 build and decided on using the Avonbar Phase 2. But........I haven't bought it yet and so was thinking about the difference between supercharger and turbo cams. I haven't seen one advertised, but I am aware of one in Oz. Vizard and a couple of other turbo books I have read go on about the importance of opening the exhaust valve early. I assume that the 2 cam specs for an identical engine would just vary on this point. (assuming that you keep the lobe centre angles the same). I'm going to find out for sure before I waste my money. Allthough a P2 looks good at the moment for what I want......Do you use them on standard rockers? I have heard you do.......anyone?
Bugger off, I'm getting there. |
6th Oct, 2004 at 09:06:56pm
Giallofly, the problem in Austria is we have only a few, very expensive RR. If you go there these guys often see a SU carb for the first time!!
6th Oct, 2004 at 09:34:25pm
Turboharry,
7th Oct, 2004 at 10:14:53pm
Hi Giallofly,
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
12th Oct, 2004 at 02:44:22am
i have the kent turbo not sure what one as i got no papers with it but it is supposed to be 649(exhaust) and 544 (Inlet) plus 1.5's non roller goes really good road and strip but i have been thinking of changing but do not know what to get.
179hp on 12psi 1293cc of pure A series
15th Oct, 2004 at 02:50:01pm
well guys after much Deliberation by all, THANKS. it would be nice for every one to put there engine specs (ie) cam,compression,boost ,power, outputs, etc on this thread. it will enable ALL to juggle the configurations and make a better choices for future engine rebuilds.
15th Oct, 2004 at 03:11:16pm
That is a good idea.
15th Oct, 2004 at 04:07:05pm
THANKS TOM i have just done so.
16th Oct, 2004 at 04:49:23pm
Good idea...
23 Posts Member #: 1089 Member |
24th Nov, 2006 at 11:55:14pm
To all,
First 5-port EFI turbo in the world (built 1997, running in 1998) |
27th Nov, 2006 at 06:47:57am
Apparently this KCRTM is probably a KC500. I will be throwing this one in as I've been told its the best race turbo cam and since I don't use my car for street use anymore I think that will be ok.
4th Jan, 2007 at 06:16:30pm
I was reading this alng with all the other threads a search for phase2 (& pahse 2) threw up but can not find the lift figures .... anybody know? Every day is a school day ...........
4th Jan, 2007 at 06:41:10pm
I found the data on here recently, but cannot found it now.
6th Jan, 2007 at 12:54:44am
286 at high comp. ratio |
" - I will give it a try for next season!
