| Home > Show Us Yours! > My stage 2, 998 A+ | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
21st Jun, 2010 at 10:25:34pm
That was the dwell, too short. Now it makes 100hp @0.90bar and 5200 rpm. Assuming 15% transmission losses, which is low. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
21st Jun, 2010 at 10:30:48pm
0.9 bar boost
Edited by alpa on 21st Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
22nd Jun, 2010 at 09:56:43pm
Peak torque at 5200 !
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
23rd Jun, 2010 at 10:15:04am
The camshaft is timed properly, I did it on the bench and the chain (double) had 10000km.
23rd Jun, 2010 at 10:57:01am
On 23rd Jun, 2010 alpa said:
Also I'm using the MPi intake which is not really a MPi plenum to me even if runners are long and strait. Maybe the throttle is not very hi flowing ? What about a Metro intake drilled for the injectors ? On 23rd Jun, 2010 alpa said:
I think if I had a better designed exhaust I would get torque past 6000. The lower the max torque, the better pulling engine so I don't understand why you are looking for high RPM, gearbox reliability ? On 23rd Jun, 2010 alpa said:
Unfortunately I can not find RR curves for turbo 998 or even 1300. What about Vizard's book in the chapters about forced induction ? On 23rd Jun, 2010 alpa said:
Still the car is perfectly drivable in the traffic and you just don't imagine what you are driving until you go past 3500rpm. As in pretty fast then scary fast or as in standard 998 then scary fast ? If the last one, then it's definitely not the setup I am looking for ... I will be running a GT15 off a 1.5 liter diesel and hope it to boost early and get the sort of torque you have à 5200 from 3000 on. But I didn't crunch any numbers so I am probably day dreaming. Last question, those 0.9 bar are on standart pistons ? And what about your CR ? (could be dumb but I am in the quote window so can't check around if you already mentioned it) Rusty by nature
23rd Jun, 2010 at 01:21:12pm
I understand what you mean about cams. But 266 is definitely not a long duration cam, just a bit more than 256 which is a good street cam.
Edited by alpa on 23rd Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
23rd Jun, 2010 at 08:05:46pm
Thanks for your straight answers.
Rusty by nature
23rd Jun, 2010 at 08:24:49pm
I assume you have developed the power curve from a G measurement?
23rd Jun, 2010 at 09:29:24pm
Paul:
23rd Jun, 2010 at 09:32:23pm
Hey, 5 + 7 kg off :)
23rd Jun, 2010 at 09:34:57pm
The other problem is to find good tires for my 12" steel rims. Mine spin. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
24th Jun, 2010 at 10:29:00am
hiding: it's mandatory to have stock appearance with closed hood. So I/C is difficult to place. MOT controllers don't notice IHI. rad: I cut the front longside/below the bumper and removed the crossbar that links front lights. Before the rad was fixed on the engines frame, this time I welded fix points to the body. Alternator is standard and not moved. Fan is a 10" from ebay in US, $35 I think. Those MOT controllers are blind then
I understood you wanted to hide stuff but now I see you just want to have it under a standart round nose, so we have the same target. Rusty by nature
24th Jun, 2010 at 11:11:51am
They are not blind, it's hard to notice IHI if you don't know what to look for, it's totally underneath intake manifold. Ok the DV is a bit visible, I'd prefer it in black.
24th Jun, 2010 at 08:37:19pm
How about PowerDyn, is it user friendly ? Rusty by nature
25th Jun, 2010 at 10:26:49pm
PowerDyn is very easy to use. But you have to have a clean signal from the engine or ABS sensor. Low voltage ignition is the best source. I use an old version I bought years ago, I'm not aware about evolutions. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
4th Sep, 2010 at 07:29:44pm
A short update.
Edited by alpa on 4th Sep, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
4th Sep, 2010 at 08:10:52pm
Your car must be a surprise to all those Cooper look alike owners, GTi's and so on ;-D Rusty by nature
5th Sep, 2010 at 11:04:32am
That's a good result. It's now running very similar figures to mine - 998/g295/T2 0.85 bar 112hp @5700 105lbft.
857 Posts Member #: 1778 Post Whore Northants |
5th Sep, 2010 at 11:09:07am
On 5th Sep, 2010 Paul S said:
At the moment I hit the rev limiter when it is still pulling like a train. Especially since you realised you had the soft cut limiter coming in at 5500rpm
5th Sep, 2010 at 11:12:57am
Very similar figures to mine too (at a gusss). Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Sep, 2010 at 12:57:14pm
Wich one Wil, the 20 hours daily ? Rusty by nature
5th Sep, 2010 at 03:44:04pm
On 5th Sep, 2010 Advantage said:
Wich one Wil, the 20 hours daily ? I've sold that one, I never had it on the rollers but I don't think it mad over 100bhp. The Sabre Sprint has over 100 when running 12psi. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
5th Sep, 2010 at 06:12:48pm
At the moment I hit the rev limiter when it is still pulling like a train. Especially since you realised you had the soft cut limiter coming in at 5500rpm ![]() Actually it was 5700rpm, but the power was still climbing. If it can still do 105 lbft at 6000rpm, then that will be 120hp. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Sep, 2010 at 10:13:59pm
At the moment I hit the rev limiter when it is still pulling like a train. Likewise. This morning I did a small test: I'm reaching 180km/h really easily with even 500mbar of boost. Well my tires are rated 190km/h and the speed limit is (usually) far below so I won't play up to 200. Just received Toyo A032-R for track days. The funny thing is that under 3500RPM it's just an ordinary well tunned Mini 1000, passengers are surprised when it starts pulling hard. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
7th Sep, 2010 at 08:37:15pm
Is the 998 gearing that high ???
Rusty by nature
