Home > General Chat > Rear Discs - What Calipers - Piccies
ministef1
Member #: 1791
Cranleigh, surrey
they look heavy mike, whats the weight saving?
"Cars are a lifetime of pain"
best_stig
Member #: 6449
Brisbane, Australia
Do they fit into the standard subframe? And then use coilovers? Or are they something different?
In boost we trust
Standard subframe or beamaxle using coilovers. Stef they weigh nothing compared to a standard arm. All the weight is in the disc and hub.
Owen
Member #: 6496
Somerset
Off to the shot blasters you go! lol
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
Did any one else spot the lack of clearance on the arms for a Mini wheel and tyre?
What kind of spacing are they?
mcalvert39
Member #: 442
Manchester
I spotted that aswell,
What about the rear hub assembly off an MGF?
Lol 1st thing i checked, they just catch on my rims but i run spacers anyway. At a minimum i would need to run a 5mm spacer.
On 14th Jun, 2010 MikeRace said:
How is this legal then?
On 13th Jun, 2010 pickmeup said:
the rear disks on my crx still uses the hydraulics to work them without a seperate mechanical action
I just looked at a spare rear caliper and it appeared to have a mechanical attatchment to it. If I get a chance I'll have a prod around the rear of the car.
Hehehehehee.
The disc on the hub in the pic is 7" in dia. Thats a cooper disc i assume. Its damn heavy though. The hub and disc are double the weight of the arm.
Mike, it might be worth placing these arms over the top of a standard arm to see where the hub face is in relation to each other. I reckon there is a fair amount of spacing already built into those.
Hurry up and get them on the car with some wheels on so we can see how far your wheels will stick out.
Not that I am trying to be negative*happy* I was watching those too.
Also, you are aware that Fastcarl does some ally hubs for rear discs, that look not dissimilar, but clearly far far lighter?
http://www.rallydesign.co.uk/product_info....oducts_id=11370
4 pot is a bit much though, and their other hyromechanical caliper is for vented discs only.
Sprock just been mulling that one over. Ill compare them up tomoz.
what about of another small fast car like the gtti
http://www.camskill.co.uk/products.php?pli...28s68p379&rs=gb
codd_coupe
Member #: 1772
Leicestersheershire
What about MGF rear calipers? I've got them on the GTM back end, they have got the built in handbrake mechanism, are self adjusting. All I needed to do, was to sort out some shorter cables.
Tim Rowe
"Is est totus perfectus per fumi quod speculum"
GTM Coupe Turbo
This could be good, how did they bolt up?
Si P
Member #: 912
North Yorkshire
As Tom has already mentioned. My friend has just fitted 205 rear calipers to his mini. He did make his own hub and disc to suit though.
Fitted under 12 inch wheels but I think would fit under 10's.
I'll take some pics next time I'm round there.
Si
supermotolee
Member #: 2153
kings langley
hi spec make some nice calipers with handbrake mech
