| Home > General Chat > major issue need help please people, sorry for the wrong section | |||||||
27th Aug, 2011 at 10:05:03pm
On 4th Aug, 2011 eden7842 said:
well my head gasket went well gutted, its just leaking some coolent into #3 On 6th Aug, 2011 eden7842 said:
ok, so ive put it all back together and it looks like i have the same problem. On 22nd Aug, 2011 eden7842 said:
its running like a sack of shit in general. runs lean before boost, then perfect on for about 500 - 1000rpms untill it does the cut out thing. just drove a 35min drive home which should of took 15. some one else already pointed out that it says on the tin that the oil was not suitable for a turbo engine? I'm not having a go, but simply trying to suggest a possibe cause for your oil to turn to sludge in such short time scale. I have never seen anything like it, and i'd be surprised if anyone else has. On 26th Oct, 2004 TurboDave16v said:
27th Aug, 2011 at 11:34:48pm
right well ive stripped and cleaned it all out today and il get the pics up 2moz for you all to laugh at!
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
28th Aug, 2011 at 01:10:21am
28th Aug, 2011 at 10:04:16pm
haha almost just uploading pics now 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
28th Aug, 2011 at 10:20:42pm
bit ot but my input, the comma classic stuff used to be green and i used it for years then one oil change the new stuff was a golden colour but came out the same steel can, i had endless problems with the golden stuff really bad rocker cover mayo another gallon later and same problems i change brand.. sorted i will never use it again Yes i moved to the darkside |
28th Aug, 2011 at 10:52:11pm
cheers brett gd to know.
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
28th Aug, 2011 at 11:07:32pm
All very well and good but I dont use comma classic either, i use the sonic, here are the data sheets-not a million percent different but clearly a different product
On 26th Aug, 2011 Coupe said:
On 26th Aug, 2011 oli79 said:
For me cant beat comma sonic, there is a bloke at my local autojumble who does it for £16 a gallon, I usually get all that he has. Halfords Classic is made by Comma - same as the Comma Classic stuff. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
28th Aug, 2011 at 11:35:41pm
Make sure you pop the oil gallery plugs out and clean everything out if you haven't already. Isambard Kingdom Brunel said:
29th Aug, 2011 at 09:51:22am
rob:
29th Aug, 2011 at 09:53:26am
going to check my oil now, fingers crossed 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
29th Aug, 2011 at 12:22:38pm
Not being funny mate, but several people, not just myself have told you to pull it appart.
29th Aug, 2011 at 12:57:45pm
i did check one of the shells, and ive done about 30 miles in it now, so i think it would be knocking by now. its also had some oil purge through it and 3 oil and filter changes now 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
30th Aug, 2011 at 11:32:55am
you could try and it helps to use 50/50 cheap O oil and parafin 3 fluses and then one oil flush and a few filters inbetween the the goo oil and new filter
34 Posts Member #: 4608 "Member" |
30th Aug, 2011 at 02:08:22pm
On 25th Aug, 2011 eden7842 said:
right well i changed the oil a week ago (but not the filter) after my head cracked and i was burning coolent. the oil wasent that contaminated that came out. thats your problem, you should have changed the oil filter, and run a flushing agent through it aswell. i highly doubt it was the halfords engine oil, halfords oil is made by comma, and comma is one of the worlds leading and largest oil refining companies, (they are so because they manufacture oil for the likes of wilkinson, tesco, halfords etc etc etc) i agree with others though that i wouldnt put cheap oil anywhere near a high performance engine, oter than purely running in, |
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
6th Sep, 2011 at 11:05:26am
i would not run the new oil for long. and put a new oil filter and oil in again..
6th Sep, 2011 at 06:34:10pm
i seemed to have solved it, its has 3 oil changes so far over around 150miles going to do another when i get back from stanford on sunday 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
