| Home > Help Needed / General Tech Chat > help with an rts clutch | |||||||
![]() 489 Posts Member #: 9159 Senior Member Devon |
25th Oct, 2011 at 07:52:17pm
Good stuff!
25th Oct, 2011 at 08:41:26pm
On 5th Oct, 2011 John said:
It would seem to tally. As before we stripped the van and had ultralight on we had no box troubles. Since fitting RTS we're getting some graunch on second. We're going to strip the box to investigate anyway but seems odd that it would seem smooth as a cashmere codpiece before rts and rough as a bears arse after!? I am however wondering if our RTS wasn't quite disengaging? I would say you are spot on there - its not dis engaging. Mine doesn't fully - I can hear the drop gears change note when the clutch is disconnected and sometimes it doesn't fully. Richard has the answer - to extend the pin in the slave cylinder to disconnect fully. This, along with a new arm, is my plan for the weekend On 7th Nov, 2011 apbellamy said:
25th Oct, 2011 at 10:01:15pm
What are peoples thoughts on the material used for the centre hubs. Yet again ive taken my flywheel off to find half of the hub still on the taper of the crank! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Oct, 2011 at 10:26:06pm
I recon its all this lapping in bollox. That and imballance, which causes the fretting.
25th Oct, 2011 at 10:34:39pm
Quite probably a good reason why not, but if my understanding is correct, the fretting is due to small movements between crank and fly, these over time cause the high spots to pick up, this then gets worse and worse.
25th Oct, 2011 at 10:37:18pm
Ive just found this, which is quite interesting.
25th Oct, 2011 at 10:50:50pm
25th Oct, 2011 at 11:29:27pm
i used the theory of heating ( or rather warming) the flywheel and torquing it onto a cold crank so when i cools it grabs, and it was a bastard getting it of when i thought the primary oil seal had gone Yes i moved to the darkside |
8th Feb, 2012 at 08:29:58pm
. Edited by Sprocket on 11th Sep, 2012. On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2012 at 09:55:35pm
On 8th Feb, 2012 Sprocket said:
This will be the best RTS clutch you can currently build, and if AP Racing were to do one, it probibly wouldn't look much differet. You just have to look at their other racing clutches. That's a brave statement. I could buy a Banham RS200. It wouldn't look much differet to a Ford RS200, but underneath there would be an Austin Maestro.... |
8th Feb, 2012 at 11:07:31pm
8th Feb, 2012 at 11:30:45pm
Mine came from Robert himself, I do not have the ability to build something like this. From talking to him it is obvious that there is more work that can be put in to the clutch to make it work better, hence why some RTS's feel different to others.
9th Feb, 2012 at 12:28:41am
Mmm cheese on toast. If your make some Nic I will have a slice I run a supercharger and I don't care the TB is on the wrong side.
9th Feb, 2012 at 12:38:29am
9th Feb, 2012 at 12:58:25am
I think the price is fantastic especially since you have put the extra thought and all the leg work into it
9th Feb, 2012 at 08:20:32am
If AP made one, it would be a single spring of appropriate thickness.
9th Feb, 2012 at 12:16:51pm
My clutch is made by carlsberg... https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
82 Posts Member #: 9772 Advanced Member Sheffield |
9th Feb, 2012 at 08:09:10pm
Can anyone tell me what kind of verto clutch this is please.
9th Feb, 2012 at 08:11:18pm
9th Feb, 2012 at 09:53:50pm
Have you made any changes to the drive straps? Im running 4 on mine, i thought better be safe than sorry. my drive staps are removable, but i couldn't get any more the same in time, i now have some however but i will be building another rts as soon as this slips although i think grip on the road will give long before this slips Yes i moved to the darkside |
10th Feb, 2012 at 10:46:26am
Well good work then, I hope it goes well for you Sprocket, After your past issues with your engine, I hope you get the machining of this correct otherwise your bollox may take a pounding! As how many have you tested mate as these could be very dangerous! Edited by Miniwilliams on 10th Feb, 2012. Best 1/4 mile 13.2 seconds @116 mph
10th Feb, 2012 at 02:06:01pm
10th Feb, 2012 at 02:08:11pm
10th Feb, 2012 at 02:12:58pm
10th Feb, 2012 at 02:18:47pm
