| Home > Help Needed / General Tech Chat > drive shaft /KAD hub problem | |||||||
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
12th Dec, 2012 at 07:30:54pm
What driveshaft plunge have you got?
David. |
13th Dec, 2012 at 12:09:45pm
the KAD hubs do give more negative camber though, which wont help this...
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
13th Dec, 2012 at 02:04:26pm
Have you checked the tie-rods against STD ones, they might be way to short ?(if they are ajustable jobbies) "So wat we gonna do tonight Brain?"
1 Posts Member #: 9676 Junior Member |
25th Mar, 2013 at 10:59:03pm
did you fix the problem?I was wondering what drive flanges you were using |
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
26th Mar, 2013 at 08:05:17am
Hi, took the advice and left it for a while till everything is correct in place.........
![]() 517 Posts Member #: 9931 Post Whore brighton |
1st Apr, 2013 at 09:34:39am
Clubbie 70 imrunning metro flanges and all seems well |
1st Apr, 2013 at 09:34:41am
![]() 539 Posts Member #: 6807 Post Whore York |
1st Apr, 2013 at 10:20:23am
Regardless of what flanges you are using, the outer cv can't come any further through than where it hits the inner bearing race, so the flanges shouldn't make any difference to this issue at all. |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
10th Apr, 2013 at 07:16:30pm
I have the 21A2693 upper arm fitted on the left with what looks like a Metro drive flange.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
