Home > Help Needed / General Tech Chat > turbo itself leaking oil
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
mine is fresh build its 25 ish hot at 1000rpm oil light is out almost instantly its a 3 bolt turbo pump alu body job
i believe anything over 60 peak when hot is to much and at idle 20 is plenty but would expect it to be 30-40 anything over 2krpm
to much oil pressure is just killing hp and extra ware on parts it also heats the oil up more
it also depends if your running oil jets to as they will flow a decant amount that the relif whont have to
coopdog
Member #: 9628
Will report back when I get my oil pressure gauge hooked up
On 9th Sep, 2014 theoneeyedlizard said:
Makes 0psi at the moment eh.
Mines as low as 25-30psi hot.
bastard! lol
Yeah 20-25 at idle is fine, 40-60 psi at about 4k. cold you dont really want over about 70.
Haha. I meant Paul's, but I suppose yours is the same!
...spose I couls spinn it on the starter
tadge44
Member #: 2500
Buckinghamshire
That is encouraging because my engine has slowyt been losing oil pressure, but it has stabilised at 20 ish at idle, hot, but 40 when hot at running speeds.
The engine in the van, despite shortening the relief valve spring runs 75 cold and 40 hot at idle !
with standard spring and shuttle the pressure is normally around 40psi,
it can dropp off a bit with old oil too.
coopdog
Member #: 9628
turbo place said theres isnt anything wrong with the turbo.
the next thing to check is the oil pressure
coopdog
Member #: 9628
well got the back together and running
on cold it went up to 60 psi
at running temp it was 40-45 psi
when reved it went back to 60 psi
its not leaking anymore, should i still try and get it down to the 20 psi mark?
Edited by coopdog on 11th Sep, 2014.
coopdog
Member #: 9628
http://www.youtube.com/watch?v=MqDgjoxV58M...X9ZT53vSTv1RAkA
i have trouble embedding vids haha
If it's not leaking now and the turbo rebuilders haven't die anything, then it must have been the feed or drain leaking.
coopdog
Member #: 9628
i had to move the orientation of the turbo the first time and i have a feeling i might of not done the half moon washers up tight enough :/
this time when i had to set the orientation i did them up nice and tight.
could this of been the problem?
also i havent driven it under load yet..
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
that pressure is fine imo
could be possible its only a small dia o ring with little crush so any unequal pressure would probably make it leak some..
coopdog
Member #: 9628
i drove it!!!
it was awesome!!!!!!!!!!!!!!!
coopdog
Member #: 9628
thanks for all the help guys.
just a couple of things to sort out like the dump valve. the spring inside is way to hard and isnt even opening when coming off the accelerator, just had a load of turbo flutter instead which did sound good haha
thank you again guys *happy*
coopdog
Member #: 9628
I've got another problem guys it's leaking again :/
It's leaking again from the same place and started after coming on boost,
Do you think it could be a breather problem as well as I have only the one.
Thanks guys
Shauna has one breather on the rocker cover and it seems fine, the oil drain shouldn't be restricting the oil return as long as both are adequately sized (braided brake hose feed ~3/4mm and 5/8 return)
I would personally take your turbo to a different specialist for a 2nd opinion if you can't solve the problem, I dont think anybody has ever had much trouble with this problem that wasn't easily solved. You could try a known good turbo, that will tell you if the problem is in your setup, your engine (bad rings, inlet stem seals/guides etc) or your turbo itself.
coopdog
Member #: 9628
theres isnt anyone around with one i could borrow thats the thing :/
the only other option i was thinking about would be a scvanger pump
You could fit a scavenger pump, although i don't think anyone has ever had to fit one, and still have the same problem. Does it leak oil when not driving? As in stationary on the drive? If so, take the drain hose off the turbo, fit a longer one to a clear container on the floor and check the flow, if the smoking/leaking stops it's probably the fall on the return. Obviously don't run the engine for long because you'll be losing oil under pressure.
Shauna
Member #: 10424
Swansea boyo!
I've seen your thread on tmf about fitting one and your oil pressure is slightly less than mine too and I still don't have any problems with only having one breather although if I did take my engine out I'd add another. What have you actually done to try stop it leaking since last time?
coopdog
Member #: 9628
it leaks oil when its up to temp and thats when its standing still too,
the only thing is i cant get to the drain when everything is in place which means everything is too hot to touch :/
is there any where else i can drain it too at all other than the speedo drive? :/
have you got a pic of your oil drain at all?
i havent done anything at all because ive been in uni since september, im going home for christmas and i want to have another go at it, hence the post haha
Shauna
Member #: 10424
Swansea boyo!
So people have given you advice, you haven't tried anything and your asking for advice on what seem like you were going to do anyway? I don't think I've got a photo of my oil drain due to most of my build photos being on my old phone but it's pretty much the same as anyone elses. Lawson knocked mine up for me, he just asked what angle I wanted and it's fine. I assume your still using that copper one with 2 90 degree bends if you haven't done anything?
I don't think i have a picture, but it's pretty much a fuel pump blanking plate with a 90 degree pipe welded onto it pointing towards the turbo, and the turbo has pretty much the same affair but coming down and across to point at the drain, slight fall on it, and i had to drop the turbo and manifold on and slide it across into the short piece of hydraulic hose already fitted to the drain on the block.
coopdog
Member #: 9628
my turbo sits wayyyy to close for that to work for me, the drain ive made is the only thing i could do to fit one *indifferent*
I think there's only about 5mm gap between the two metal pipes on shaunas, its very tight, but can be done.
