| Home > Help Needed / General Tech Chat > help on loss of power | |||||||
7th Jun, 2017 at 09:17:14pm
Just to add to the low comp etc I'm running 1.5 rockers !!!!! |
7th Jun, 2017 at 09:39:17pm
Turn the boost up. This is the only logical solution.
In the 13's at last!.. Just |
7th Jun, 2017 at 09:47:32pm
GT20what? On 26th Oct, 2004 TurboDave16v said:
7th Jun, 2017 at 09:49:03pm
On 7th Jun, 2017 theoneeyedlizard said:
Turn the boost up. This is the only logical solution. Who used to say that the ph2 is a 'hungry cam'? Benross? Fab said it was a "hungry lion" lol Which Gt20 are you using ? Is it the correct 2056 from the Iveco ? Phil. |
7th Jun, 2017 at 09:56:58pm
On 7th Jun, 2017 cossierick said:
Just to add to the low comp etc I'm running 1.5 rockers !!!!! Take those off for a start! that is an even bigger barn door On 26th Oct, 2004 TurboDave16v said:
7th Jun, 2017 at 10:05:09pm
7th Jun, 2017 at 10:08:09pm
I will say I'd be supprised that you would drop so much hp from th cr reduction, so do check the cam timing first, Tom knows what hes doing obviously, but none of use are immune to a cock up!
7th Jun, 2017 at 10:29:51pm
the GT2056 is nearly on the surge line at 2:1 pressure ratio and 10 - 11 Lb/Min air.
8th Jun, 2017 at 06:20:30am
Wow bigger can of worms for me to look into .
Edited by cossierick on 8th Jun, 2017. |
8th Jun, 2017 at 08:14:10am
what dose the engine read on a normal compression test? 90psi? 7.5 is really low imo that thing wants plenty of boost |
8th Jun, 2017 at 10:16:17am
I concur with Sprox, take the 1.5s off.
8th Jun, 2017 at 10:42:43am
I've done a lot of simulation work on what may be the ultimate 5 port using a 1293, GT2056, 1.5 rockers and the "Nic" cam which is not dissimilar to the Ph2. It's true that the GT2056 is the bottleneck and a change to a GT22 added 30hp without any other changes because it opened up the exhaust side.
8th Jun, 2017 at 10:47:55am
I like all the suggestions to wind the boost up If something is worth doing, it's worth doing half of. |
8th Jun, 2017 at 10:53:39am
On 7th Jun, 2017 apbellamy said:
JB Weld the piston crowns to bring the CR up? ![]() next, you'll be suggesting a gaycharger |
8th Jun, 2017 at 11:41:07am
Thank you all so much with you help i really do apreciate it .
8th Jun, 2017 at 06:02:49pm
Compression check done !
8th Jun, 2017 at 07:45:15pm
Sounds pretty reasonable,
9th Jun, 2017 at 12:27:19pm
So lets agree that the cam timing is right !
9th Jun, 2017 at 12:40:24pm
Ummm... the Ph2 has an LSA of approx. 110 cam degrees. I would have timed it in at 110. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
177 Posts Member #: 10990 Advanced Member Hornsea |
9th Jun, 2017 at 12:53:18pm
I am at mallory next Friday also. Hope you can get it sorted in time.
9th Jun, 2017 at 12:53:36pm
deffinatly check the cam timing, its my favorite for being the issue.or at least contributing.
9th Jun, 2017 at 01:19:14pm
looking at that data, I'm pretty sure mine is timed in wrong............ |
9th Jun, 2017 at 01:19:31pm
Roy fingers crossed.
9th Jun, 2017 at 01:34:10pm
best thing then is stick a DTI on the exhaust valve to see what the lift is,
12th Jun, 2017 at 09:01:16pm
Shit , I was just going to update this thread but just seen your last comment Joe ! I haven't measured to see which cam it was .
