| Home > Technical Chat > Water Injection..... | |||||||
16th Sep, 2011 at 08:02:37pm
Yes, if I had one. It would be switched on rev's rather than boost.
16th Sep, 2011 at 08:09:35pm
Mines on at 5psi... seems pikey but works. I run a supercharger and I don't care the TB is on the wrong side.
16th Sep, 2011 at 08:32:39pm
You can start using it at very low boost, but unless it's a progressive system you will probably have to compromise the benefit at high boost to flow little enough at low boost not to cause a misfire. Although mine isn't set up yet on the mini, the system on the Maestro (not progressive) doesn't kick in until 20psi, where it starts to need it to allow the ignition timing that it is set at. The mini will probably be very similar in setup, maybe coming in a bit sooner but it's hard to tell at this stage. Progressive systems are great, but are a pig to set up properly and not much real benefit in the real world. Unless you can lap a track consistently enough to notice tiny changes as it comes on boost out of corners etc, you will never notice the difference. |
16th Sep, 2011 at 08:34:18pm
my car only runs to 10psi I run a supercharger and I don't care the TB is on the wrong side.
16th Sep, 2011 at 08:37:20pm
Should work a treat then! :)
On 16th Sep, 2011 gr4h4m said:
my car only runs to 10psi |
16th Sep, 2011 at 09:26:36pm
im going to have a bash at adapting my ecu to make the water injection fully mappable like fuel injection
Yes i moved to the darkside |
857 Posts Member #: 1778 Post Whore Northants |
16th Sep, 2011 at 09:48:45pm
If your using water injection to lower intake temps would it not be best to trigger on IAT/MAT? Turn on at 50 degrees and hysteresis of 10 so only turns off when temps drop back below 40?
16th Sep, 2011 at 10:28:58pm
You use it to lower intake and combustion temps and allow a combination of more boost and timing to make more power. It's (almost) pointless reducing temps if you don't tune to take advantage of it |
17th Sep, 2011 at 07:57:58am
Stick it in pre turbo Brett. More boost for nearly free. On 11th Feb, 2015 robert said:
17th Sep, 2011 at 09:28:27am
both Yes i moved to the darkside |
17th Sep, 2011 at 03:24:05pm
No point. You can't make air already at ambient temp any colder or more dense by adding water at the same temp.
On 17th Sep, 2011 apbellamy said:
Stick it in pre turbo Brett. More boost for nearly free. |
17th Sep, 2011 at 04:17:53pm
ah, but you can boost the compressor efficiency by sticking it in pre turbo,
17th Sep, 2011 at 05:33:35pm
I've just been reading up on it. Best results are about 4% mass air flow increase using water/methanol mix. With water alone it I'd guess at nearer 2%. I suppose the disadvantage is that you can inject less after the turbo/ic as the saturation limit is fixed. The more you use pre turbo to gain mass flow the less you can use later where it would prove most beneficial for reducing heat. Swings and roundabouts.. not sure it's worth the wear on the turbo..
17th Sep, 2011 at 05:49:45pm
increasing the power fucks everything faster lol
On 17th Sep, 2011 Joe C said:
ah, but you can boost the compressor efficiency by sticking it in pre turbo, you can also fuck the compressor wheel though... Yes i moved to the darkside |
17th Sep, 2011 at 05:53:11pm
not on mine...everything fucks quickly whatever... On 28th Aug, 2011 Kean said:
17th Sep, 2011 at 07:57:19pm
On 17th Sep, 2011 jamie@thefatgarage said:
I've just been reading up on it. Best results are about 4% mass air flow increase using water/methanol mix. With water alone it I'd guess at nearer 2%. I suppose the disadvantage is that you can inject less after the turbo/ic as the saturation limit is fixed. The more you use pre turbo to gain mass flow the less you can use later where it would prove most beneficial for reducing heat. Swings and roundabouts.. not sure it's worth the wear on the turbo.. It would be interesting to see some dyno results for it. I doubt anyone could tell the difference driving it. If you read the extensive thread on the Aquamist forum. There is no evidence at all to suggest spraying pore-compressor causes any wear worth worrying about But if you are not pushing the compressor very hard, injecting pre compressor is probably not worth while compared to pushing it very hard. 9.85 @ 145mph
10th Oct, 2011 at 08:06:55pm
http://www.alcohol-injection.com/en/49-nozzles Yes i moved to the darkside |
10th Oct, 2011 at 09:13:26pm
noticed no damage on my turbo when squirting pre-turbo :) .. now run post turbo for other reasons but it was fine. turbo 16v k-series 11.9@118.9 :)
10th Oct, 2011 at 09:20:48pm
i did put "CAN" lol.
10th Oct, 2011 at 10:35:13pm
i dont see it as much of a problem, but then i have no hard evidence or experience of either way only from the net, think about suck through turbo set-ups where does the fuel go ?? ok there not that common but still there is more fuel going through them than water in a WI set up
