| Home > General Chat > 5-main alloy block with steel crank & rods to suit | |||||||
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
1st Jul, 2010 at 02:18:39pm
Oh & i see a little Marlene left nipple sticking through her rashy,,, maybe it was a little cold after all www.miniman.com.au
1st Jul, 2010 at 02:27:18pm
On 1st Jul, 2010 MadMatt said:
I don`t think ill be making up any kits of this engine to sell,,, i might need to win the lotto to complete this engine ![]() The shock nearly knocked me of my chair when I read that statement.
1st Jul, 2010 at 03:08:47pm
oh yeah,,, & i thought the rods & block was such good value that it would balance out the cost of the crank www.miniman.com.au
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
1st Jul, 2010 at 03:37:55pm
what size is the longboard your riding in that snap?
the pissed up clown stood back up, did a twirl and left bollock naked, |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
1st Jul, 2010 at 09:37:31pm
I didn't understood quite right.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
1st Jul, 2010 at 09:41:45pm
On 1st Jul, 2010 Advantage said:
I didn't understood quite right. You sourced an alternative block or had one done ? If it is the first, then why don't you use it's dedeicated cranck and mate it with a chain drive to the mini gearbox ? And what was the plan about the gearbox anyway ? Isn't it a known weak link even in full race trim ? On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2010 at 03:04:03am
Oli,,, mine is 11ft (i have a pile of other boards of various sizes) but as you well know , on waves this "BIG" ,,,well i think i chose the right board for the day hey? www.miniman.com.au
2nd Jul, 2010 at 07:36:04am
& here`s "one" of the single over-head cam carriers we`re playing with,,, (This one`s a ford one) i`m doing a few different designs (for a few different engines) & will sort out what`s best & what`s not
Edited by MadMatt on 2nd Jul, 2010. www.miniman.com.au
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
7th Jul, 2010 at 02:50:42pm
matt is a smart guy, he knows his stuff.
Edited by NickG on 7th Jul, 2010. |
7th Jul, 2010 at 08:48:52pm
douple post ... Edited by Advantage on 7th Jul, 2010. Rusty by nature
7th Jul, 2010 at 08:49:16pm
I like the over head cam conversion !
Rusty by nature
7th Jul, 2010 at 08:54:07pm
Oh Matt you fucker!
there`s quite a bit of work in these things & this (being our first attempt) has already shown some flaws in my design, so we learn from our mistakes & make the next one better-er, hey? the short alloy shaft laying ontop is just a dummy cam plug, so don`t hold to much concern with it ok? On 28th Aug, 2011 Kean said:
1083 Posts Member #: 8932 Post Whore |
7th Jul, 2010 at 10:53:55pm
Nice idea, i hope you do succeed this will be great if you do, not sure if i missed anything but are you going to be using a standard gearbox case? and what sort of head do you have in mind? good luck with it i'll be following the progress. :) |
8th Jul, 2010 at 06:06:59pm
On 22nd Apr, 2010 Advantage said:
My crazy thoughts of a few weksbacks was to use two A series camshaft in overhead design for a X flow 16 valves head. Could work for 8 valves thought ... http://www.turbominis.co.uk/forums/index.p...quote_id=357967 Rusty by nature
10th Jul, 2010 at 05:10:01am
Thanks Guys,,, well there`s really 2 things going on here,,, one is the 5-main donk with a "certain" Multi-valve cyl head,
www.miniman.com.au
10th Jul, 2010 at 05:20:56am
I didn't understood quite right. You sourced an alternative block or had one done ? If it is the first, then why don't you use it's dedeicated cranck and mate it with a chain drive to the mini gearbox ? And what was the plan about the gearbox anyway ? Isn't it a known weak link even in full race trim ? I sourced an alternative cyl-head & block, (half-block actually) but adding to that half-block & making it a 2-piece block the crank from that block is too short (stroke wise) & even if it were long enough (capacity speaking) then it still doesn`t allow for fitment of a decent drive to the box (reliability/strength wise) yes,,, "Decent" torque kills the mini box,,, so yes we do have plans for a decent box, but it will come later... obviously if we can produce 200hp -ish smooth in n/a form from this 5-main multi-valve donk & hoping for big chunks of torque from it too,,,, then yes you`re correct & the box is obviously not going to have much fun,,, we`re well aware of that & have already started looking at other options... the first engine (if it works) will be 1650cc (1647 to be precise) so it "should" have quite a bit of grunt,,, i can only imagine what it would be like turbo charged
I have some help from quite a few well known Aust Automotive/Marine/industrial engineers & as much as they are old & stuffed when it comes to hands-on,,, their brains are still ticking over quite well (so-far)
besides all that,,, i need them for all their wondefull CNC machining equipment
Edited by MadMatt on 10th Jul, 2010. www.miniman.com.au
14th Aug, 2010 at 01:27:40am
ok, we`ve had some progress with this 5-main crank, with alloy billet block
Edited by MadMatt on 25th Aug, 2010. www.miniman.com.au
339 Posts Member #: 399 Senior Member Austria |
29th Sep, 2010 at 11:17:07am
any progress?
1st Oct, 2010 at 06:39:25pm
I`m a little short on money for the crank atm, sorry, & too busy fighting off alligators to realise the original intention was to drain the swamp... if you know what i mean www.miniman.com.au
