| Home > Help Needed / General Tech Chat > I fooked up but how bad? water feed... Updated 18-11 new pics on page 3 | |||||||
20th Nov, 2012 at 08:54:01pm
Ur lucky you didont drill into the piston 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
20th Nov, 2012 at 09:01:32pm
What bore is it 73.5?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
319 Posts Member #: 1742 Senior Member essex |
20th Nov, 2012 at 09:04:24pm
wow that is impresive.i know thats no help but good luck sorting it
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
20th Nov, 2012 at 09:35:42pm
yea +0.020"
On 20th Nov, 2012 MikeRace said:
What bore is it 73.5?? |
20th Nov, 2012 at 09:47:22pm
That block is a bargain at £20!
20th Nov, 2012 at 10:09:19pm
I agree with matty, or even magic metal?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
21st Nov, 2012 at 09:11:18pm
thanks Matty could you recommend someone up to the job?
On 20th Nov, 2012 matty said:
That block is a bargain at £20! Why don't you get it welded up? Then tidy the weld up with a die grinder/bearing scraper. Its only skirt clearance at that point anyway.
We have castings welded up all the time at work. |
22nd Nov, 2012 at 07:54:09am
We have castings welded up all the time at work. bore distortion due to heat ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Nov, 2012 at 07:02:58pm
By the time you've buggered about I would just prepare a new block. On 7th Oct, 2010 5haneJ said:
388 Posts Member #: 442 Senior Member Manchester |
23rd Nov, 2012 at 07:49:50pm
Gutted as you maybe. I know i would be, id still cut my losses and go with a new sutible block. Its less worry. If you get this one welded up that niggling thought will always be with you. (Will it work)? |
23rd Nov, 2012 at 08:11:16pm
Sleeve!!!! On 13th Jul, 2012 Ben H said:
23rd Nov, 2012 at 09:15:11pm
On 23rd Nov, 2012 Vegard said:
Sleeve!!!! Bless you On 26th Oct, 2004 TurboDave16v said:
29th Jul, 2017 at 12:02:41am
This is brilliant even 5 years on lol.
29th Jul, 2017 at 08:01:29am
My build thread..
224 Posts Member #: 9987 Senior Member Amsterdam |
29th Jul, 2017 at 10:15:17am
Smart! |
