| Home > Help Needed / General Tech Chat > Boost | |||||||
![]() 428 Posts Member #: 10128 Senior Member Dorset |
13th Dec, 2020 at 07:50:33pm
That's a new one for me, the Metro had a pipe to the breather system as standard from that union. Trace the wire and see where it goes? |
![]() 114 Posts Member #: 11728 Advanced Member Uden, Holland |
14th Dec, 2020 at 06:22:22pm
The wire seems to go inside the car, but the entire loom is wrapped, so it’s hard to see where it is going. |
15th Dec, 2020 at 02:12:51pm
Never seen any kind of sensor fitted there. As standard it just has a non return valve and a pipe to the engine breather system. Has it had an electronic boost gauge fitted in the past, and this was the sensor for the gauge? |
15th Dec, 2020 at 03:15:55pm
Not that I know off.
Edited by Yoda74 on 15th Dec, 2020. |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
15th Dec, 2020 at 06:46:34pm
If its an oil pressure switch it will go to ground when 4psi is reached of exceeded. I'd be curious to temporarily terminate the cable to it to ground and see if its been used as a signal to switch your (and I use the term loosely) boost control?
15th Dec, 2020 at 08:10:08pm
I already bought a new switch.
19th Dec, 2020 at 11:08:38am
Got the old switch out and got the new one in.
25th Dec, 2020 at 08:45:00am
As I didn’t know what to do on Christmas morning I thought, let’s pull out the ecu, open it and check it for visible faults.
25th Dec, 2020 at 02:50:30pm
Quite basic....they've just fitted a complete GM style MAP sensor inside it.
25th Dec, 2020 at 07:00:02pm
Thanks for the info Stevie.
17th Jan, 2021 at 02:25:01pm
Last week I send the ecu to a well known Dutch Mini garage.
Edited by Yoda74 on 17th Jan, 2021. |
257 Posts Member #: 11017 Senior Member Shropshire |
17th Jan, 2021 at 02:44:26pm
Personally i'd have binned that ecu ages ago and fitted a modern EBC. |
17th Jan, 2021 at 03:30:04pm
Every person has his own preference |
17th Jan, 2021 at 09:32:33pm
Any progress to report?
18th Jan, 2021 at 05:37:59am
@ Shane: read 3 replies back |
18th Jan, 2021 at 07:49:51am
Apologise I completely missed that post.
18th Jan, 2021 at 08:08:50am
Looks a lot like it, less the plug.
