Home > Help Needed / General Tech Chat > Megajolt again
colas
Member #: 102
Pennsylvania USA
Hi
My megajolt runtime display will not show RPM therefore the advance is staying the same. The MAP value is changine but the advance is fixed at 25. I'm currently running the TT map. Any ideas????
hippyinamini
Member #: 520
nr hull
i had a similar problem and it was down to me wiring the saw and pip wires the wrong way round between the jolt and the edis4 unit, might be worth double checking.
steve
doh! why did i start messing with it!
colas
Member #: 102
Pennsylvania USA
Hi
I went and looked at it and found that the pip wire had come out. Its working again.
Thanks
jamesfawcett
Member #: 218
Bingley, West Yorkshire
On mine it was the software got it working on a different computer it kept crashing
