| Home > Help Needed / General Tech Chat > twin boost setup | |||||||
8th Jul, 2006 at 07:02:23pm
just thought i'd check this setup is ok as it is slightly different to diddy's setup and i my bleedvalve is the 3 legged type, do 2 way bleed valves have literally 2 legs on them as some of the ones i've seen have 2 legs and a hole, this i assume is actually a 3 legged type for under bonnet use.
9th Jul, 2006 at 01:26:53am
thats exactly as mine is, use a 2 legged one if you dont want to run a solenoid, or are willing to plumb it in a bit different |
9th Jul, 2006 at 02:44:11am
Does that mean then if i use that diagram above that with the switch off that the boost will just be whatever the actuators set at, then when you flick the switch it'll run at whatever the bleed valves set it to?
9th Jul, 2006 at 10:01:50am
Yup, with the solenoid closed you would be using actuator pressure.
9th Jul, 2006 at 11:56:35am
tart |
9th Jul, 2006 at 02:11:38pm
bastards, I got a solanoid of ebay ages ago with the intension to do this, thought I would be something special :( |
9th Jul, 2006 at 04:58:15pm
i don't think you'd need two bleed valves as you could just open the one shown above halfway and this would therefore give more boost when the solenoid is opened (via the switch), however when the solenoid is closed and the bleed valve is still open the lower boost would just be what the actuator is set at. |
208 Posts Member #: 438 Senior Member London |
9th Jul, 2006 at 08:08:56pm
If you wanted to get really fancy, you could get a solenoid operated idle air control valve (Ford?) and feed it with a pwm current.
10th Jul, 2006 at 11:19:37am
Quote sumpnut
621 Posts Member #: 393 Post Whore Oulton Park |
10th Jul, 2006 at 11:32:20pm
This the bad boy i spent my money on http://www.demon-tweeks.co.uk/products/Pro...e=AETFG-GBCV-DS |
