| Home > Help Needed / General Tech Chat > stud help | |||||||
9th Jul, 2006 at 05:23:16pm
i have just put all my arp studs in the block ready for the head
9th Jul, 2006 at 06:24:03pm
sorry im not a stud, so i cant usually help
9th Jul, 2006 at 06:47:08pm
As nic says really, but if you dont fancy drilling out the existing at this time seing as its in the car, ,check the thread in the block, [should be 5/16 UNC], and use two capscrews of the correct length and thread type.
9th Jul, 2006 at 07:22:48pm
I got a 7.8 mm(? correct size ?) drill and unc start and finish taps if you need them
9th Jul, 2006 at 09:31:25pm
Cheers Brian if i cant get a bolt will you be about tomorrow?
9th Jul, 2006 at 10:31:48pm
wolfie you might want to check the link is either 5/16, or 3/8 ,if the pic is not distorted it mliiks like the thinner of the two, which i suspect you already have tapped into the block,
9th Jul, 2006 at 11:07:55pm
On 09/07/2006 21:31:25 wolfie said:
Cheers Brian if i cant get a bolt will you be about tomorrow? i take it this is what i need? http://www.minispares.com/Product.aspx?pid=32816 Yes home at 2pm all this week,The drills and taps I have are to put normal size studs in.which ain't that hard just tape all the holes up(done it myself couple of weeks ago) If you don't wanna drill it or can't get the stud linked above I think a diff housing one fits. Dont for get to put some threadlock/sealer on the end of the stud as you get water seeping up from the water pump else
9th Jul, 2006 at 11:11:22pm
ill ring somerfords first thing see if they have the one my block is already tapped for i can shoot out to them at lunch time
9th Jul, 2006 at 11:13:57pm
Normal is 3/8 unc,waterpump one is 5/16 as that is smaller cus 3/8= 6/16
9th Jul, 2006 at 11:16:46pm
