| Home > Help Needed / General Tech Chat > Is there another way of connecting up an actuator? | |||||||
10th Jul, 2006 at 03:18:04pm
does it matter where the actuator gets it reading from?
10th Jul, 2006 at 03:29:17pm
maybe the fuel pump is goosed? whatever happens to that signal you should always see 3.5psi.
10th Jul, 2006 at 03:54:56pm
forgot to add, when coming back to idle.
10th Jul, 2006 at 04:07:32pm
What fuel tank are you using? |
1050 Posts Member #: 764 Post Whore Staffordshire |
10th Jul, 2006 at 04:49:25pm
wheres that red pipe going dude? isn't that pipe next to the fuel inlet usually blocked off to stop it dying on boost? Edited by Anton on 10th Jul, 2006. |
10th Jul, 2006 at 08:18:46pm
hi im using an MPI tank, the red pipe goes to one leg of the bleed valve (at the moment its connected straight into the blue pipe inside.)
11th Jul, 2006 at 12:59:34am
that'll be the problem then dude. The union you've got the red pipe on is for the anti-run on valve, as soon as you try to use your bleed valve your opening it it to atmosphere which means that it doesn't get fuel and tries to cut out.
11th Jul, 2006 at 08:11:23pm
Hi bud thanks for that and drawing it, but it doesnt run without daves T piece trick normally, but i will try it without the T piece trick but with the balance pipe and see what happens.
12th Jul, 2006 at 12:11:15am
Ahhhh......... Nicks most excellent artistry comes into play once more.......
12th Jul, 2006 at 12:39:16am
is he dead? |
12th Jul, 2006 at 12:42:25am
This just cannot work. I can't be arsed to explain why. Think about what you are trying to achieve by bleeding signal from the actuator line. Then think about what this drop in pressure will do to the fuel reg.
12th Jul, 2006 at 12:47:25am
yeah i was just thinking the same thing, bleeding the signal thats also connected to the reg would be dropping the fuel pressure wouldn't it?
