Home > Help Needed / General Tech Chat > Wheel stud snapped :( (update: got a new one..)
ARGHHHH
Seems like something doesnt want me to get to Avon, eh?
Just started doing up the wheel nut, got to finger tight, did one turn with a wheel brace, not even tight, and woop, twists off in my hand :(
Gay.
So, where can i get one from (like, now?) and how do you replace them?
al.
Edited by AlexB on 12th Jul, 2006.
Front or back?
They are fitted by pulling them into a taper on the disc, or into the hub for drum brakes.
For now, get a hammer and punch and drive the broken bit towards the centre of the car to remove it. On the front it should pop out and fall on the floor, on the back you will need to remove the brake drum to get the bit out.
Dicanio
Member #: 91
Front or back, disc or drums?
iv got a long one if you need it !
jamesfawcett
Member #: 218
Bingley, West Yorkshire
ah man alex feel sorry for you everything going wrong :( really hope you get everything sorted out
andeh
Member #: 97
Near Daventry, midlands
nightmare, really feel for you dude
least its not a hard change, see above.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I got spares.....
drop round :)
Alex
AlexF
lucky you
if its the rear you can get away with just lossening the hub instead of taking it right off
I've got a bag-full of all different types if you get stuck. They are always in my toolbox at events.
I always torque them to the book 63 NM after a spate of bust studs. It dosent seem tight for a wheel when you dio it though.
Cant find any local places with studs in stock at all.. Arrrghhh. Don't to miss the RR tomorrow :(
Got two!!
From Rowe's Rover in Basingstoke - Apparently the last two that Rover had in stock *happy* Being delivered to work this afternoon. Let's hope they're the right ones.
Wahoo!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
great news!
AlexF
I will call you if theyre not right though Alex *wink*
Well, they just arrived! i hope they're the right ones :)
thats awesome service too - £11.33, delivered to my door, the same day.
S1275GTt
Member #: 512
Basingstoke
£11.33 for two studs! Crikey..
I'd have paid that EACH tbh
Thats it, you can't put a price on parts in an hour of need!!!
Just hope i can fit it now. Anyone got a quick guide to replacing studs in a cooper S setup?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
take off wheel
take off disk
hammer out old stud
hammer in new stud
refitting is the reversal of removal!
Alex
AlexF
How do i take the disc off? just those four screws?
Sorry to be a numpty, but I've never changed the discs on my car.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
if its for the front, just take the wheel off, knock the old stud out with a hammer (with the broken stud at the rear of the flange, closest to the rear wheel, to avoid hitting the caliper)and stick the new stud in, so you can feel it hits the splines square, then I just put an old bolt on and screw it in without having the wheel on.
Yes, I am sure you can do this without removing the disc from the car.
When you have got the new stud poked through, I usually use a nice big socket, a washer, and a wheel nut to draw the new stud into place.
got that all in. I think my wheel bearing is totally fucked on the pass side, which is why its making crashing noises. if you hit the top of the wheel when the car is on the ground like normal, it goes CHINK.
same happens if you wobble the wheel
:( this fucking car!!!!
