Home > General Chat > im not destined to go to avon :-(
Carl
Member #: 95
liverpool-on-sea
every time i fix one thing something else breaks. im realy fooked off with it.
1. oil leak just before retro cars end casing on gearbox cracked, removed engine/box replaced end cover all ok.
2. broke gearbox casing and diff at retro cars removed and replaced this weekend.
3.oil leak from behind flywheel area(dripping out of little hole at bottom of flywheel housing) removed flywheel etc and transfer housing and replaced primery gear seal and transfer housing gasket( twat of a job with engine in). went out tonite still seems to be leaking.*frown*
4.just got back and one of my rear wheel bearings has gone.
so it looks like i might just be spectating this year.*frown*
trust me, dont think its going well for most of us!
i'm struggling with fuel pump/regulator/fuel pipe issues!! its just pumped the cylinders full of petrol!!! doh!
get there eventually i hope...
i think we all know where you are coming from carl
bat at it and be determined!
look at one job at a time and compleate it spot on
you will be at avon iam sure!
Carl
Member #: 95
liverpool-on-sea
im SURE ill be at avon just not sure the car will be there thats all,lol
i have the same thoughts every day carl!!
bring the car and the parts and ill give you a hand on sat
mine isnt going well, been twatting around with an electric water pump since fri with little sucess
completely cooked the engine today, so ill be taking some spare head gaskets to avon then!
Mate that is not good, is it, but stick at it right up till the end, youll be a happier man if you get the work finished and can take the car.
on the topic of the oil leaky clutch, are you sure the primary gear bush isnt bolloxed??, are you using the specific tool to change the seal?
Sort it carl. Rear wheel bearing is an easy job. Although not when you've not stopped working on the car for a week and you're knackered and your hands are cut to bits.
Still, sort it.
dan
Member #: 93
you can do it carl, you always make it in the end!!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Its going to be clean inside iain!! i did same thing on the red mini, and it made the inside of my engine immaculate!
