Home > Help Needed / General Tech Chat > crank differences
1976 clubamn
Member #: 400
Shrewsbury
In a previous thread i showed you my buggered turbo crank, after some recomendations i swaped the crank for one from a normal 1275 using turbo shell bearings.
when torqued up the crank is completly locked up and will not move, are there different settings i should be using for this combination??
If it breaks... build a much faster one
Was your old crank ground undersize? If it was and you have used the same bearings then they will not have running clearance and will lock up as you describe.
This is the most obvious thing I can think of.
Otherwise, torque up one cap at a time and see if it is only one cap causing the problem?
1976 clubamn
Member #: 400
Shrewsbury
the original crank was yellow and the new one is green
I have no idea what the factory colours mean unfortunately!
What I was getting at is that cranks if they get scored or worn are reground undersize to get a fresh surface back, and then physically thicker bearings are used to keep the running clearance the same.
Usual first undersize would be 10 "thou" undersize.
I'd suggest measuring your old crank journal sizes, and then your new ones, you will need something quite accurate to do this, a vernier calipers should do the trick.
Or you could also remove your bearing shells and look on the back of them, standard size will usually have "STD" stamped in, 10 thou maybe +010".
1976 clubamn
Member #: 400
Shrewsbury
thanks for the help on this. i just hope i can sort it for this weekend
You have put the center main cap back on the right way round. Are all the numbers facing the same way??
1976 clubamn
Member #: 400
Shrewsbury
i took all the kit to a local machine shop today, got the crank machined and new shells. sorted.
hope i can get it ready for avon now
Did you get it ready for Avon?
been on the pop V ?
100 months !!! there abouts
D4VE
Member #: 10749
lowestoft suffolk
Wtf 8 years!?!?!
Nothing gets past Dave lol
wayne miller
Member #: 10890
Twin Cam Turbo Build In Progress Rothwell, Northants
*Jester* *Clapping* *Rofl!* *Rofl!* *Rofl!*
Bravo Vegard. Bravo.
lol!
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
haha
V is back...
This is why Vegard is our favourite Viking
Pillaging the past again...
clubman91
Member #: 8923
North Wales
Haha
