Home > Help Needed / General Tech Chat > subframe mounts
martpaul
Member #: 668
newton aycliffe (near durham)
Hey all,
just bout to make my mini a rolling shell, but realised i dont have any mounts!
so what type do you suggest?
i have some poly subframe to floor mounts in the garage so just need tear and tower one!
which type? poly or solid!
oh the cars gonna be a 998 turbo if that helps!
thanks martin
I'd personally put solid floor and tower omnes and polly tear ones.
martpaul
Member #: 668
thanks,
and what would you say for the rear?
just while im orderin them i can order the rest!
thanks
Rear mounts are the same thing as floor mounts.....*wink*
martpaul
Member #: 668
whats the difference in the poly and solid? are the poly ones strong enough just im a little nervous bout the ride with the solids! (its gonna be a daily driver)!
martpaul
Member #: 668
sorry i meant rear subframe!
can i get away with standard on these? or should i upgrade the rear subframe aswell?
*tongue*
andeh
Member #: 97
Near Daventry, midlands
i use std ones, im not a fan of poly bushes.
JT
Member #: 637
Hertfordshire
of got solid ones on the front and standerd ones on the back.
i couldnt belive the differnce in handling with the solid front ones!! it makes it more responsive imo.
with standerd rubber ones if you get a mate to turn the wheel while stationary, you will see the whole subframe moving slightly, where as with the solid mounts it doesnt move at all!!
not sure whats best for rear subframe though.
cheers
josh
My build thread..
martpaul
Member #: 668
yeah im thinking leaving the back and sort the fronts! then see how it feels! (not like id know :) )
Polly bushes at the back are a good idea too IMO. It will be a bit rougher I guess, but minis are hardly a smooth ride.
The worst thing for choppy ride is stiff shocks. KYBs all the way for my road car.
